Forum Topic - Reply size?: (6 Items)
Reply size?
When doing a MsgSend() I am able to specify the maximum reply size, however if I receive less than the max reply size I
haven't found any way of knowing exactly how much I got back.   Is there any sort of mechanism for finding this
information?
Josh
Re: Reply size?
Normally the server will indicate in the reply message the number of data bytes.
The standard read/write routines use the status to indicate the number of bytes read/written.
I haven't found any way of knowing exactly how much I got back.   Is there any sort of mechanism for finding this
information?
> Thanks
> Josh
> http://community.qnx.com/sf/go/post39085
cburgess@qnx.com
Re: Reply size?
What about when you use a custom message.  In other words I'm using MsgSend directly with a user defined message.  There
 are cases where many clients send messages off to the server and these msgs are replied to until something changes at
the server.  The reply is used to pass back information about what has changed (note: the information varies in size
considerably depending on what is being asked for).  I would like to know exactly how much was passed back for
efficiency reasons as I need to perform memcpy's of the data and I don't want to always copy the maximum amount.
Josh
RE: Reply size?
Put the size in the message itself.
> From: Josh Schmiedlin [mailto:community-noreply@qnx.com]
> Sent: Wednesday, September 30, 2009 11:49 AM
> To: momentics-community
> Subject: Re: Reply size?
> MsgSend directly with a user defined message.  There are cases where
> to until something changes at the server.  The reply is used to pass
> in size considerably depending on what is being asked for).  I would
> like to know exactly how much was passed back for efficiency reasons as
> the maximum amount.
> Thanks,
> Josh
> http://community.qnx.com/sf/go/post39096
RE: Reply size?
When you reply:
     MsgReply(rcvid, status, buffer, len);
The "status" would be the return value of MsgSend() at the other end. So
you can:
     MsgReply(rcvid, len, buffer, len);
This way, by check the return value of MsgSend(), the sender would know
exactly how much bytes you replyed. (That's how read() function is
implemented)
On the side note, if you wish to fail the request, then:
MsgError(rcvid, err)
Would result MsgSend() return -1, with errno being set to "err".
-xtang
> Sent: September 30, 2009 11:49 AM
many
> until something changes at the server.  The reply is used to pass back
size
know
> exactly how much was passed back for efficiency reasons as I need to
maximum
> amount.
> Thanks,
> Josh
Re: RE: Reply size?
Thanks for the suggestion xtang!  I think that will work for most of the cases that I'd really want to optimize.
As a suggestion for an enhancement to the MsgSend class of functions why couldn't you do the following:
int MsgSend( int coid,
             const void* smsg,
             int sbytes,
             void* rmsg,
             int rbytes
             int &actualBytes);
In other words have the kernal modify the value of the actualBytes parameter when it copies the data from one process to
 the other.  I'm assuming the kernal knows exactly how much it copied, so it would be very easy to pass this info onto
the user at least it seems like it would be.  Just a thought.
Thanks again,
Josh
