Re: RE: Intel i82546GB / i82540 / e1000
09/17/2009 5:41 PM
post38226
Hi Hugh,
Well, starting Net with -d6 definitely helped, along with some further experimenation with command line parameters for
the Net.i82540/e1000 driver. Each driver now remains running and correctly reports link status, speed, etc. Watching
the -v output, they properly detect the cable being disconnected and then reconnected. The 'ifconfig' command can
initialize the en1, en2, en3, etc. interfaces, and the output from 'netstat -rn' looks like what I expect. Everything
_looks_ fine.
Unfortunately, I can't ping anything.
If I kill the Net.i82540/e1000 driver, start up the Net.ether82557 driver, and move my cable to the built-in ethernet
interface, ping works fine.
At the moment, I'm out of ideas.
I might try to boot a Linux liveCD or something on our system, just to make sure the hardware is working properly. (I'm
not sure how difficult that will be on our equipment, however...)
Thanks again for your earlier help, and thanks in advance for any additional ideas!
Walt
