Forum Topic - Reg: How to mount USB in qnx4.5?:
I have tried the following commands
io-usb -dehci pindex=0, verbose=4, pindex=2 &
io-usb -dohci pindex=0, verbose=4, pindex=2 &
io-usb -duhci pindex=0, verbose=4, pindex=2 &
---->It create file in /dev/usb.
Fsys.umass fsys -l -n Direct-Access=usb
mount -p /dev/usb
But it dispay,
mount -p: read() of BIOS signature on /dev/usb failed: Block device required
I had note that the usb is when ever I type the command
mount -p /dev/usb
Kindly help in this regard..
RE: How to mount USB in qnx4.5?
Please post the output from 'show_pci -v'.
From: kanda samy [mailto:community-noreply@qnx.com]
Sent: Tuesday, August 18, 2009 7:08 AM
To: qnx4-community
Subject: Reg: How to mount USB in qnx4.5?
mount -p /dev/usb
But it dispay,
required
mount -p /dev/usb
QNX4 Community Support
http://community.qnx.com/sf/go/post36143
Re: RE: How to mount USB in qnx4.5?
Hello Hugh!!
today i had a problem with my QNX harddisk. I will post the out of show_pci  tomorrow.
Is the usb device also list under the pci device? but every time I had to issue the command then only my usb device got
detected.
I found that usb is read while i give the mount command.
K.Kandasamy.
RE: RE: How to mount USB in qnx4.5?
The 'show_pci -v' command should show all of your PCI devices including
the USB and Ethernet.
Sent: Wednesday, August 19, 2009 8:13 AM
To: qnx4-community
Subject: Re: RE: How to mount USB in qnx4.5?
Hello Hugh!!
show_pci  tomorrow.
to issue the command then only my usb device got detected.
K.Kandasamy.
http://community.qnx.com/sf/go/post36248
Re: RE: RE: How to mount USB in qnx4.5?
the output of show_pci -v for usb. four device has been detected.
vendor ID = 8086h Intel corp
Device ID = 2658h
PCI index = oh
class code C0300h serial bus(universal serial bus) ProgIF = 0
Device ID = 2659h
PCI index = oh
I had check using using fdisk /dev/usb0 it shows 2 partition in one is non qnx partition and the other is dos. but while
 i try to mount it shows,
for dos partition:
insufficient memory unable to mount error
for non-qnx partition it shows BIOS signature fail for this device error.
I had delete all the partition and check with the qnx partition with the same mount option. It also display the
kindly help in this regard.
RE: RE: RE: How to mount USB in qnx4.5?
Did you perform a 'mount -p /dev/hdx' before trying a 'mount /dev/hdx'?
Sent: Thursday, August 20, 2009 8:45 AM
To: qnx4-community
Subject: Re: RE: RE: How to mount USB in qnx4.5?
Device ID = 2658h
PCI index = oh
Device ID = 2659h
PCI index = oh
non qnx partition and the other is dos. but while i try to mount it
shows,
for dos partition:
error.
same mount option. It also display the insufficient memory unable to
mount error
http://community.qnx.com/sf/go/post36363
Re: RE: RE: RE: How to mount USB in qnx4.5?
yes! I mount using the following command.
mount -p /dev/usb0
it create two file in /dev dir - 1. /dev/usb0t6 2. /dev/usb0t77
but I not able mount both the partition.
K.Kandasamy.
sorry.
i had tried the mount option like this
mount -t /dev/usb0 /tmp/usb
now its mount when not used with -t option
mount /dev/usb0 /tmp/usb
I have another problem:
when I open the usb in linux it shows the content but when i open the same in windows its not displaying (even the
partition type is FAT). also I checked the usb partion in windows with FAT and try to mount in qnx it shows corrupted
file system error.
Kindly tell I to data from qnx to windows and vice versa.
K.kandasamy
RE: RE: RE: RE: How to mount USB in qnx4.5?
You will have to run Dosfsys to be able to copy files to/from a DOS file
system.
Sent: Friday, August 21, 2009 6:04 AM
To: qnx4-community
Subject: Re: RE: RE: RE: How to mount USB in qnx4.5?
sorry.
same in windows its not displaying (even the partition type is FAT).
qnx it shows corrupted file system error.
K.kandasamy
http://community.qnx.com/sf/go/post36404
Re: RE: RE: RE: RE: How to mount USB in qnx4.5?
I had run the Dosfsys after Fsys.umass , but i got No drives found message.
when to run the Dosfsys command.
RE: RE: RE: RE: RE: How to mount USB in qnx4.5?
Did you do the 'mount -p' after running Fsys.umass and before running
Dosfsys? You can also try running 'Dosfsys c=/dev/usb0t6'.
Sent: Friday, August 21, 2009 7:56 AM
To: qnx4-community
Subject: Re: RE: RE: RE: RE: How to mount USB in qnx4.5?
message.
http://community.qnx.com/sf/go/post36408
Re: RE: RE: RE: RE: RE: How to mount USB in qnx4.5?
Thanks!!!!
Now I got my usb device mount on /doc/c with the Dosfsys c=/dev/usb0t6 option u said.
Reagrds,
K.kandasamy.
