Forum Topic - Upgrade from QNX 4.21 to QNX 4.25: (10 Items)
Hello!
I work in a factory that has QNX 4.21 installed on 5 machines - Compaq 486, running a software called Rolldata. We wanna
 upgrade this system to a more actual one mainly becouse of the old hardware and the lack of spare parts for them -
mainly HDD and ISA Novell NIC's.
I downloaded the 2008 Upgrade CD - but i get a message when i try to install QNX 4.25 Operating system - in upgrade node
 becouse of the licence problem - older licence model -  saying that Archive read error. I try with different cd unit, 2
 burned cd's and no luk!
Please help us!
With regards'
George D.
Re: Upgrade from QNX 4.21 to QNX 4.25
> Hello!
> running a software called Rolldata. We wanna upgrade this system to a more
> them - mainly HDD and ISA Novell NIC's.
> QNX 4.25 Operating system - in upgrade node becouse of the licence problem -
>  unit, 2 burned cd's and no luk!
> Please help us!
> With regards'
> George D.
I'm afraid I have no advice on your licensing problems, but I hope you won't mind this little plug.  I just wanted to
point out that we are still selling QNX 4 compatible NE-2000 compatible ISA NIC's (see http://www.betech.biz/B&E%20TECH/
PDF_files/B&E_104.pdf).
Bert Menkveld
B&E Technologies
bert@betech.biz
RE: Upgrade from QNX 4.21 to QNX 4.25
An archive read problem sounds as though you have a problem with the
install CD rather than a licensing problem.
From: George Dabija [mailto:community-noreply@qnx.com]
Sent: Thursday, July 23, 2009 2:11 AM
To: qnx4-community
Subject: Upgrade from QNX 4.21 to QNX 4.25
Hello!
486, running a software called Rolldata. We wanna upgrade this system to
spare parts for them - mainly HDD and ISA Novell NIC's.
install QNX 4.25 Operating system - in upgrade node becouse of the
I try with different cd unit, 2 burned cd's and no luk!
Please help us!
With regards'
George D.
QNX4 Community Support
http://community.qnx.com/sf/go/post34370
Re: RE: Upgrade from QNX 4.21 to QNX 4.25
Thank you for your reply, i will try with a 3-rd CD. In the meantime can you indicate a solution like using a specific
instal command? Something like /bin/install -u <upgrade kit filename>?
RE: RE: Upgrade from QNX 4.21 to QNX 4.25
You have to boot from the install CD, but you will need licenses in the
new format. You will most probably have to talk to your sales rep to get
your licenses upgraded.
Sent: Thursday, July 23, 2009 8:20 AM
To: qnx4-community
Subject: Re: RE: Upgrade from QNX 4.21 to QNX 4.25
you indicate a solution like using a specific instal command? Something
http://community.qnx.com/sf/go/post34389
About the license the only solution I know about is to contact QSS to convert your old license to the new one.
To: qnx4-community
Hello!
Please help us!
With regards'
George D.
Using "use license" under the cd - it says that is treating old style license prior to v4.23 in the /etd/licenses and
the new type in .licenses.
So that's why I wana make an upgrade. The people from we brought the license in not longer working. And now we try to
make contact to annother firm. But it take's time.
We really wanna try new hardware - PII and PIII but we need those new Fsys* drivers - that I think is working only under
 v4.25 (patch G or..).
From where do I find a Proc and a Slib so I can build annother .boot file?
I want to update my post - the error that I have - saying that "Archive read error" it's a tricky - in a shell windows
it says - whatever command I type (ls, sin info etc... ):
//1/hd0.0/bin/ksh(or ls, sin, etc.) terminated (SIGSEGV) at 000F:000005507 (different address - 0007:00006568 for ls and
 0005:00005317 for sin as examples)
sh(or ls, sin, etc.) terminated with signal 11 (same number)
Could anybody cand give me some thoughts for this errors?
The machine is a K6II at 300MHz, 128MB SDRAM.
I have to mention that this machine run QNX 4.21 with all the software up and running using a HDD from the node 1,
production station(witch is a Compaq 486 DX2 at 66MHz with 12MB of RAM - 16MB less 4 for the BIOS I belive) .
Thanks!
My guess is a hardware problem.  Probably memory.  Or a corrupted file
Sent: July 30, 2009 7:52 AM
To: qnx4-community
Thanks!
http://community.qnx.com/sf/go/post34886
Re: RE: RE: Upgrade from QNX 4.21 to QNX 4.25
Hello again!
I used the CD with a different license and it worked, then I installed my license using :
license /hd1/etc/licenses /etc/licenses
where /hd1 was the mounting point to original hdd and make another attempt with upgrade and this time it worked fine (
upgraded my Watcom C compiler).
I try now to upgrade the other 2 nodes with HDD and the real life test(in the factory).
So, apparently the error is the license. I suspect that is the license for the operating system - named for the ksh
shell. Can anyone have other ideas?
With respect,
George D.
