Forum Topic - QNX425 on PCs HP compaq:
We need to install QNX4.25 on HP Compaq dc5850 PC with ATI Radeon 3100 video and Broadcom BCM5754 network. The Net.
bcm57xx driver does not support the 5754 chip. If you run with parameter-d167A (0x167A is the Device ID), after 55
seconds it prints "no VPD", but work properly, perhaps.The Pg.Radeon video driver does not support the model 3100.
Do you know of any updates or what parameters can I use?
RE: QNX425 on PCs HP compaq
Please try the attached network driver and let me know if it works.
Thanks, Hugh.
From: nose quien [mailto:community-noreply@qnx.com]
Sent: Tuesday, July 21, 2009 11:25 AM
To: qnx4-community
Subject: QNX425 on PCs HP compaq
video and Broadcom BCM5754 network. The Net.bcm57xx driver does not
Device ID), after 55 seconds it prints "no VPD", but work properly,
QNX4 Community Support
http://community.qnx.com/sf/go/post34209
Attachment: Text Net.bcm57xx 48.1 KB
Re: RE: QNX425 on PCs HP compaq
Hugh, thanks you very much by help us
We can use your driver, it didn´t need the parameter -d to run, but it works like the another, after of 55 seconds it
prints "No VPD" and starts
RE: RE: QNX425 on PCs HP compaq
I have no idea why the driver is taking 55 seconds to start up. The "No VPD" message is just a warning. There is not
much that I can do about the driver without the hardware.
Hugh.
From: Fausto Espinillo [mailto:community-noreply@qnx.com]
Sent: Wednesday, July 22, 2009 4:23 PM
To: qnx4-community
Subject: Re: RE: QNX425 on PCs HP compaq
http://community.qnx.com/sf/go/post34347
Re: RE: RE: QNX425 on PCs HP compaq
The PC is a HP compaq dc5850 Microtower
We run the driver with -s100 -v parameters, and it prints:
Net-bcm57xx: PCI-Express Card (b002)
I/O port base ...... 0xf0400000
Interrupt ........... 5
Net.bcm57xx:   Actuve PHY :  5787
50 sec.
Net.bcm57xx:  No VPD
Net.bcm57xx:  Link down
buffer stuck at 318!
Net.bcm57xx:  Link up
Maybe this information could be usefull
Thank's anyway
There is no updated graphics driver for this chipset.   It may work with
one of the generic drivers but I can't say for sure as we haven't tried
it here.
Sent: July 21, 2009 11:25 AM
To: qnx4-community
that´s rigth, we found that Hydra.ms and Pg.flatdc32 work with good resolution but very slowly. We´ll try to change
the parameters.
Thanks you very much!
We don´t get good results with generic drivers
We can use video devices PCIe added
Could you recommend some graphic device of the market ?
Thank´s
Fausto
