help with intel 810 graphics driver
03/04/2009 12:26 PM
post23498
I replaced the motherboard on an Audio Request ARQ1 music server that was having audio issues. The system is running QNX
4.25 on an intel i810 chipset motherboard. The original motherboard was a AZZA PT810-DTC. The replacement is an AZZA
PT810-DM. The chipsets are identical.
For some reason the VGA output is not working properly. I keep getting 'out of range' error on my monitor. The TV-out
was recognized and is functioning properly, so it would seem that the graphics are working properly, just not through
the 'VGA out'
The settings in sysinit.node for the mode switcher are: vesabios.ms -i0x03 -r -cnone -nnone
Settings in crt.node are: i810bios.ms -i0x112 -r;Pg.i810 -HC0x00000008 -PX -HNqnx/crt -g640x480x24 -A0xD0000000,0x100000
-WB1920
I've tried switching to graphics mode from within photon (qnx4/graphics/drivers/vesabios.ms -i0x12 -cnone -nnone) and
starting a standard driver (Pg.vga4 -g640x480x4 -A0xA0000,0x10000 -WB80 &) as well as trying the intel Pg.810 driver.
Is there a flag set somewhere I'm missing? The transition to the new motherboard was perfect except for the display
adapter.
Any suggestions, opinions?
Thanks-
