Forum Topic - XML: (9 Items)
XML
I am getting ready to make a simple XML file parser for QNX 4.25. But, I wanted to see if anyone has already got
something or even started on something that I could take over. Has anyone out there attempted to use XML in 4.25 before?
RE: XML
Expat compiled pretty easy if I remember correctly.  I think TinyXml (C++) also worked nice.   All these are parser only
, can't use them to create XML data.
> From: John Walsh [mailto:community-noreply@qnx.com]
> Sent: March-03-09 9:13 AM
> To: qnx4-community
> Subject: XML
> I wanted to see if anyone has already got something or even started on
> XML in 4.25 before?
> QNX4 Community Support
> http://community.qnx.com/sf/go/post23311
Re: XML
I ended up writing my own state driven push parser, so I can dump XML into it from file or TCP connection without having
 to sit in the middle of parser. Lets me process each field as it becomes available (not worried about XML well-formed
issue) rather than wait till end of XML statement. As XML takes over as the defacto protocol of everything (including
the machine control stuff we deal with), I decided that it was worth the effort to do my own rather than work around
issues with open source/freeware stuff
For whats worth
Dave
RE: XML
> From: dave allamby [mailto:community-noreply@qnx.com]
> Sent: March-04-09 12:07 PM
> To: qnx4-community
> Subject: Re: XML
> into it from file or TCP connection without having to sit in the middle
> worried about XML well-formed issue) rather than wait till end of XML
> (including the machine control stuff we deal with), I decided that it
> was worth the effort to do my own rather than work around issues with
I believe SAX parser will do just that, by design.
> For whats worth
> Dave
> http://community.qnx.com/sf/go/post23494
Re: RE: XML
Thanks Mario and Dave. I tried Expat but had some issues with /sys/mman.h. The version I have apparently doesn't have
madvise() and a few define statements. Also my version of <stdio.h> doesn’t have snprintf(), vsnprintf(), and a few
others. I’ve been trying to find versions that will get it to compile but have yet to get it working. The print
statements I think I could work around easy enough. But I’m at a loss as to another way to advise the kernel how to
handle paging or if it is OK to just comment these calls out.
   I’ll try the other suggestions. Thanks again.
RE: RE: XML
> Sent: March-11-09 2:36 PM
> To: qnx4-community
> Subject: Re: RE: XML
> /sys/mman.h. The version I have apparently doesn't have madvise() and a
> snprintf(), vsnprintf(), and a few others. I’ve been trying to find
> The print statements I think I could work around easy enough. But I’m
> at a loss as to another way to advise the kernel how to handle paging
Hum, don`t remember what version of expat I used but as far as I can remember it compile as is.  I do have snprintf and
vsnprintf in our library though so it might have make it easier.
> http://community.qnx.com/sf/go/post24171
Re: XML
>  or if it is OK to just comment these calls out. I’ll try the other
You can probably chuck the madvise stuff code and the snprintf
and vsnprintf() just live in different headers ... but other than that
you should be able to get expat working ok.
Thomas
RE: XML
> From: Thomas Fletcher [mailto:community-noreply@qnx.com]
> Sent: March-13-09 12:02 PM
> To: qnx4-community
> Subject: Re: XML
> and
> I’m
> paging
I'm not sure but I believe that the expat I used provided its own version of *nprintf().
> Thomas
> http://community.qnx.com/sf/go/post24330
Re: RE: XML
Just downloaded the latest greatest version of Expat...2.0.1
I get all kinds of issues when I run ./configure most of which again look to be caused by headers. Did any of you figure
 out which version you got to configure and make OK under 4.25?
I've attached the config.log. If anything jumps out at you...any advice would be greatly appreciated.
Attachment: Text config.log 55.75 KB
