12/03/2008 11:37 AM
post17856
I have a problem with mouse sensitivity being too great, I want to slow it down.
I am running QNX4.25 on a Siemens Simatic Panel 677B PC with an integrated mouse.
I have tried changing:
/etc/config/trap/input
using different permutations for the swtches 'rel -G -T' but this does not have the desired response.
I have also copied some source code from the QNX knowledgebase but variables 'gain' and 'threshold' are not declared in
the structure '_pointer_ctrl',
pointer.h. I am using Watcom 10.6.
Here is the code:
#include <sys/pointer.h>
#include <Ph.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/kernel.h>
#include <sys/sendmx.h>
union {
struct {
struct _Ph_msg_forward forward;
} send;
struct {
struct _Ph_msg_hdr_reply hdr;
int result;
} reply;
} msg;
struct {
PhRegionDataHdr_t hdr;
struct _interact_mgr info;
} region_data;
main(int argc, char *argv[])
struct _Ph_ctrl *ph;
int gain;
PhConnectId_t conn_id;
struct _pointer_ctrl ctrl;
PhRect_t rect;
PhRegion_t region;
PhRid_t rids[10];
int nreg;
int i;
struct _pointer_ctrl pctrl;
struct _mxfer_entry smx[2], rmx[2];
extern struct _Ph_ctrl *_Ph_;
if (argc > 1)
gain = atoi(argv[1]);
else gain = 2;
if ((ph = PhAttach(NULL, NULL)) == NULL)
perror("PhAttach");
conn_id = PhGetConnectId();
if ((nreg = PhQueryRids(Ph_RIDQUERY_TOWARD, 0, 0, Ph_PTR_REGION,
0, 0, NULL, rids, 10)) <0)
perror("PhQueryRids");
printf("Found %d ptr regions: %dn", nreg, rids[0]);
if (PhRegionQuery(rids[0], ®ion, &rect, ®ion_data,
sizeof(region_data)) <0)
perror("PhRegionQuery");
for(i = 0; i <MAX_DEVS_PER_MGR; i++) {
if (region_data.info.devices[i].type == _INTERACT_TYPE_POINTER) {
printf("Found a INTERACT_TYPE_POINTERn");
break;
pctrl.type.handle = region_data.info.devices[i].handle;
pctrl.type.type = region_data.info.devices[i].type;
pctrl.type.feedback = region_data.info.devices[i].feedback;
pctrl.gain = gain;
pctrl.threshold = 0;
msg.send.forward.hdr.type = _Ph_SERV_POINTER;
msg.send.forward.hdr.subtype = _POINTERSETCTRL;
msg.send.forward.pid = region.owner;
msg.send.forward.len = IOCPARM_LEN(_POINTERSETCTRL);
_setmx(&smx[0], &msg.send, sizeof(msg.send));
_setmx(&smx[1], &pctrl, sizeof(pctrl));
_setmx(&rmx[0], &msg.reply, sizeof(msg.reply));
_setmx(&rmx[1], &pctrl, sizeof(pctrl));
if (Sendfdmx(ph->fd, 2, 2, smx, rmx) <0)
perror("Sendfdmx");
printf("Message sent successfullyn");
printf("Result code is %dn", msg.reply.result);
Any ideas?
