Forum Topic - Net.i82540....:
Net.i82540....
We updated our server with an Intel S5000XVN motherboard with has an intel network controller with 82563EB intel network
 chipset. I used the Net.i82540, the one in patch 701, and apparently everything was fine, the driver was up ok, but
when I tried to ping to another machine on the network, it didn´t work. Of course I cant´t telnet the server. Is there
 any updated to the Net.i82540 driver ? I really appreciate any help, I have one server down for this situation. Thanks
in advance for any help..... Victor Gamboa
RE: Net.i82540....
Please try the attached driver and let me know if it works. If not, then I will need the output from 'show_pci -v'.
From: Victor Gamboa [mailto:vgamboa@computech.com.mx]
Sent: Monday, June 30, 2008 9:14 PM
To: qnx4-community
Subject: Net.i82540....
QNX4 Community Support
http://community.qnx.com/sf/go/post9878
Attachment: Text Net.i82540 34.05 KB
Re: RE: Net.i82540....
Thanks for your help. I used the driver that you send, but apparently everything was fine, but I still can't ping or
telnet. I am attaching the show_pci -v output as you requested me, and I got the next message too:
//1/bin/show_pci terminated (SIGSEGV) at 00D1:000019AA %1 45 Memory Fault show_pci -v
I thanks again for your help. Victor.
Attachment: Text show_pci.txt 21.46 KB
RE: RE: Net.i82540....
Please will you try the attached experimental driver. The name has been
changed, as this is a completely new driver and has not yet been
released.
Sent: Wednesday, July 02, 2008 6:38 PM
To: qnx4-community
Subject: Re: RE: Net.i82540....
everything was fine, but I still can't ping or telnet. I am attaching
too:
Fault show_pci -v
http://community.qnx.com/sf/go/post9975
Attachment: Text Net.e1000 118.87 KB
Re: RE: RE: Net.i82540....
Hugh:
      Thanks.... thank you very much. With the new driver Net.e1000 works. I can ping and telnet the server now. Thanks
again. Victor
RE: RE: RE: Net.i82540....
Good news! Thanks.
Sent: Thursday, July 03, 2008 1:03 PM
To: qnx4-community
Subject: Re: RE: RE: Net.i82540....
Hugh:
works. I can ping and telnet the server now. Thanks again. Victor
http://community.qnx.com/sf/go/post10035
> released.
Just want to add that I installed this driver on our server because Net.i82544 was crashing on a daily basic when there
was lots of traffic ( running at 1Gig). Since running Net.e1000 not a single crash in over a week.
> To: qnx4-community
> too:
> Fault show_pci -v
Good news! Thanks Mario.
Sent: Monday, August 11, 2008 11:44 PM
To: qnx4-community
been
> released.
Net.i82544 was crashing on a daily basic when there was lots of traffic
week.
> To: qnx4-community
> too:
> Fault show_pci -v
http://community.qnx.com/sf/go/post11664
Re: RE: RE: RE: Net.i82540....
I tried it on a different hardware PCIe and did is 0x10b9 and the drive can't detect the hardware even if try forcing
the id with -d10b9.
> To: qnx4-community
> been
> > released.
> week.
> > To: qnx4-community
> > too:
> > Fault show_pci -v
RE: RE: RE: RE: Net.i82540....
Please give this one a try. It works with my 0x10b9 device.
Hugh.
Sent: Sunday, August 24, 2008 4:20 PM
To: qnx4-community
Subject: Re: RE: RE: RE: Net.i82540....
can't detect the hardware even if try forcing the id with -d10b9.
> To: qnx4-community
> been
> > released.
traffic
a
> week.
> > To: qnx4-community
apparently
attaching
message
> > too:
> > Fault show_pci -v
http://community.qnx.com/sf/go/post12322
Attachment: Text Net.e1000 188.61 KB
Re: RE: RE: RE: RE: Net.i82540....
> Hugh.
Hello Hugh,
I finally figured out that it doesn't work on a particular model of IBM.  I take the same NIC and move it around from PC
 to PC and only on IBM x3650 does it fail.
I can see it with show_pci so it's detected.  What i'm not sure about is if the card is enable, its status is 0x10 and
the command register is 0x147 (maybe 0x157 not sure)
RE: RE: RE: RE: RE: Net.i82540....
Mario,
Please can you send me the full "show_pci -v" output from the IBM
machine with that adapter installed?
Thanks, Hugh.
Sent: Monday, August 25, 2008 2:59 PM
To: qnx4-community
Subject: Re: RE: RE: RE: RE: Net.i82540....
> Hugh.
Hello Hugh,
I take the same NIC and move it around from PC to PC and only on IBM
x3650 does it fail.
if the card is enable, its status is 0x10 and the command register is
http://community.qnx.com/sf/go/post12393
Re: RE: RE: RE: RE: RE: Net.i82540....
> Mario,
There you go, just noticed I used -vvv
> Thanks, Hugh.
Attachment: Text show_pci.txt 53.87 KB
RE: RE: RE: RE: RE: RE: Net.i82540....
The reason that it did not work on the IBM is that the device is on bus
28. The driver only scans 25 buses, so I have added a -b command line
option. Please try starting the attached driver as 'Net.e1000 -b30 &'
and see if that works.
Hugh.
Sent: Monday, August 25, 2008 3:31 PM
To: qnx4-community
Subject: Re: RE: RE: RE: RE: RE: Net.i82540....
> Mario,
> Thanks, Hugh.
http://community.qnx.com/sf/go/post12399
Attachment: Text Net.e1000 119 KB
Re: RE: RE: RE: RE: RE: RE: Net.i82540....
1 down 1 million to go ;-)
Do you have a netinfo that works with this driver?
RE: RE: RE: RE: RE: RE: RE: Net.i82540....
Here you go.
Sent: Monday, August 25, 2008 4:22 PM
To: qnx4-community
Subject: Re: RE: RE: RE: RE: RE: RE: Net.i82540....
bus
http://community.qnx.com/sf/go/post12404
Attachment: Text netinfo 210.38 KB
Re: RE: RE: RE: RE: RE: RE: RE: Net.i82540....
I tried this driver with the quad version of the board, using
Net.e1000 -I0 -l1 &
Net.e1000 -I1 -l2 &
Net.e1000 -I2 -l3 &
The first two invocations work, but the third fails with
INITIALIZATION ERROR 4
net_reg failed
Is there a way to get this working with the quad board?
Kevin
Is your Net started with "-d4" parameter?
PKY
RE: RE: RE: RE: RE: RE: RE: RE: Net.i82540....
You will have to start Net with 'Net -d4 &'. Net defaults to 2 drivers.
From: Kevin Miller [mailto:community-noreply@qnx.com]
Sent: Tuesday, August 26, 2008 4:38 PM
To: qnx4-community
Subject: Re: RE: RE: RE: RE: RE: RE: RE: Net.i82540....
Net.e1000 -I0 -l1 &
Net.e1000 -I1 -l2 &
Net.e1000 -I2 -l3 &
net_reg failed
Kevin
http://community.qnx.com/sf/go/post12467
Re: RE: RE: RE: RE: RE: RE: RE: RE: Net.i82540....
Great posts!
We will buy an Intel S5000PSL motherboard this week.
It has the same intel network controller 82563EB, but two Intel Xeon quadcore
I will test the driver as soon as possible and post the results
Regards, Mario
Network works under Neutrino 4.4.1 using S5000Psl from Intel
(same chipset for network)
Regards, Mario
hallo,
i have a network card with intel chipset 82540, than i found the driver Net.i82540, but that driver look like not
working
properly, because usually if i use command Net.i82540 -v & , its should be come out the list of hardware like  mac
address number and other, but in this case it is not coming out and i need the mac address to setting the network.
is any body  have a problem solving for my problem.
thanks
dodi s
Hi Dodis,
I do not know which version of install CD you are using, but if you read back through this thread you'll see that Net.
i82540 has been replaced by Net.e1000..  If you are using the 2011 CD or later then you should have the Net.e1000 driver
 already installed on your system.  If not, you  can get the latest Net.e1000 (or any other newer drivers that are
available)  from this page:  http://community.qnx.com/sf/wiki/do/viewPage/projects.qnx4/wiki/LatestSoftwareUpdates
which might be a good idea to get even if you do have the 2011 CD installed.  Note: If you don't have 2011 CD installed
and you just get the latest driver, you will not have updated versions of some network utilities ... the versions you
have will not recognize this driver.  I don't know the exact list , but remember reading about a utility that needed
updating in this thread.
Also if you don't see the info you want when running a driver with "-v"  add more v's... i.e. "-vvvv"... the more v's
you add the more info you get (up to a point).
-Martin.
From: dodi sunardi [mailto:community-noreply@qnx.com]
Sent: Wednesday, March 23, 2016 12:07 AM
To: qnx4-community <qnx4-community@community.qnx.com>
hallo,
working properly, because usually if i use command Net.i82540 -v & , its should be come out the list of hardware like
mac address number and other, but in this case it is not coming out and i need the mac address to setting the network.
thanks
dodi s
http://community.qnx.com/sf/go/post116007
To cancel your subscription to this discussion, please e-mail qnx4-community-unsubscribe@community.qnx.com
