Forum Topic - A new netinfo utility is needed.:
In the our system we are using Net.rtl8169 driver which is started
as follows:
Net.rtl8169 -d 0x8168 -m 000003000062 -l1
Looks like that network operates ok, but netinfo fails with the following error message:
Driver Slot 0:  Driver Pid 74  Logical Net 1  Network Card: Ethernet/UNKNOWN SUBTYPE 39
and this is version from Patch G:
   netinfo  184897  Feb 10  2003
Is there any newer release?
Jacek
Re: A new netinfo utility is needed.
second
also, netinfo translates error codes to text only up to code 3884
specifically, we would like to know the meaning of codes 3900 and 3907
thank you,
stepan hejny
aveco
RE: A new netinfo utility is needed.
Here is an updated netinfo.
Sent: Wednesday, May 21, 2008 8:03 AM
To: qnx4-community
Subject: Re: A new netinfo utility is needed.
second
thank you,
stepan hejny
aveco
QNX4 Community Support
http://community.qnx.com/sf/go/post8296
Attachment: Text netinfo 224.25 KB
Re: RE: A new netinfo utility is needed.
Works fine :-D !!
Tested and verified with two different NICs.
Thank you,
Jacek
