Re: cp command cause root directory is gone (/ point is unmounted)
09/05/2018 4:21 PM
post119074
Hi Chris,
This is QNX 4 discussion board, but your question about QNX 6 (next version). Please repeat your question in right forum
5 сент. 2018 г., в 19:05, Chris Liang <community-noreply@qnx.com> написал:
> I encounter a problem that using cp command to copy a large file (~1GB size) from USB to SD card or vise versa. during
copying, error out and root directory is gone (/ mount point is umounted).
> The following is verbose from cp:
> cp: LSTAT(/dos/d/,buf)
> cp: LSTAT(/log/file.121,buf)
> cp: copy_guy(/log/file.121,/dos/d///file.121)
> cp: OPEN(/log/file.121,0,0)
> cp: OPEN(/dos/d///file.121,2401,100640)
> cp: LSTAT(/dos/d///file.121,buf)
> cp: Copying /log/file.121 to /dos/d/file.121
> cp: write (/dos/d///file.121): Input/output error
> cp: ERRS++ (1) write()
> 88.74% (755840/851673 kbytes, 2323 kb/s)
> cp: read (/log/file.121): Bad file descriptor
> cp: ERRS++ (2) read()
> cp: past_data_copy errs_in =0, errs = 2
> cp: exit_copy_guy (rc=0)
> cp: CLOSE(fildes)
> cp: close (/log/file.121): Bad file descriptor
> cp: ERRS++ (3) _close()
> cp: CLOSE(fildes)
> cp: close (/dos/d///file.121): Bad file descriptor
> cp: ERRS++ (4) _close()
> QNX version: 6.4.1
> both SD card and usb key is running on USB bus. I can see during copy devb-umass and io-usb processes are taking CPU
usages
> what could be the root cause of this?
> Thanks in advance.
> QNX4 Community Support
> http://community.qnx.com/sf/go/post119073
> To cancel your subscription to this discussion, please e-mail qnx4-community-unsubscribe@community.qnx.com
