10/07/2015 10:06 AM
post114602
is I211 supported on QNX4 via Net.e1000?
I got Net.e1000: INITIALIZATION ERROR 1 when I used the following command:
Net.e1000 -v -d1539 -l1-I0
Device 1539 - Revision 3
net_reg failed.
Re: I211 support for QNX4
10/07/2015 11:06 AM
post114603
Please try the attached driver. You don¹t need to pass the device ID on
the command line.
>net_reg failed.
>QNX4 Community Support
>http://community.qnx.com/sf/go/post114602
>qnx4-community-unsubscribe@community.qnx.com
10/08/2015 6:40 AM
post114606
Thanks, but I still got the errors, should I get a new version for /bin/Net?
Cmd:
Net.e1000 -v -l1-I0
After fix-ups FlowControl is now = 0
Forcing Speed and Duplex
M88E1000 PSCR: 0x3150
Full Duplex
Forcing 10mb
Unable to establish link!!!
Initializing the Flow Control address, type and timer regs
Masking off all interrupts
NVM work 0x03 is not mapped.
NVM word 0x03 is not mapped.
//1/bin/Net terminated (SIGSEGV) at 0015:000003D8
Net.e1000: INITIALIZATION ERROR 3
net_reg failed.
10/08/2015 8:39 AM
post114607
I¹ll have to take a look at this when I get a chance. Are you connecting
to a 10Mb network?
>/bin/Net?
>Cmd:
>Net.e1000 -v -l1-I0
>Full Duplex
>Forcing 10mb
>net_reg failed.
>http://community.qnx.com/sf/go/post114606
10/08/2015 8:45 AM
post114608
I have 6 I211 ports, but only one of them is connected to a 100M network,
I tried for each port, they all got same output.
the Net was got from the QNX 4 Product Suite CD 2015 EXPERIMENTAL,
and the Net.e1000 is the attched driver. I'm not clear if they are matched.
> to a 10Mb network?
10/08/2015 10:55 AM
post114610
Are the I211 adapters on PCIe boards? If so, could you please give me the
Intel name of the adapter?
Thanks, Hugh.
>matched.
>> to a 10Mb network?
>http://community.qnx.com/sf/go/post114608
10/08/2015 6:05 PM
post114613
All the I211 ports are located on a single customized motherboard, I think they are just like the
prototype provided by intel.
the functionalities of the ports have been validated under Windows7 and Linux.
please let me know if you want anything in detail.
> a
> Thanks, Hugh.
> >matched.
> >> to a 10Mb network?
10/09/2015 2:00 PM
post114618
Please try the attached driver and let me know if it works.
Thanks, Hugh.
>Linux.
>>the
>> a
>> Thanks, Hugh.
>>network,
>> >matched.
>>connecting
>> >> to a 10Mb network?
>http://community.qnx.com/sf/go/post114613
10/09/2015 10:44 PM
post114619
It reported the same error as previous revision:
the last line indicted this caused the memory fault of Net
%1 80 Memory fault Net -d6
any other hidden options can expose more debug information?
> Thanks, Hugh.
> >Linux.
> >>the
> >> a
> >> Thanks, Hugh.
> >>network,
> >> >matched.
> >>connecting
> >> >> to a 10Mb network?
10/10/2015 1:36 AM
post114620
Upload the picture of the failure.
> > Thanks, Hugh.
> > >Linux.
> > >>the
> > >> a
> > >> Thanks, Hugh.
> > >>network,
> > >> >matched.
> > >>connecting
> > >> >> to a 10Mb network?
10/10/2015 3:01 AM
post114622
more details found with -vvv (curious, I can't use console redirection to save all the log to files, but other app can,
so I have to type the last screen to you, any suggestion?)
e1000_check_alt_mac_addr_generic
e1000_read_invm_i210
e1000_read_mac_addr_82575
e1000_reset_hw_82580
e1000_disable_pcie_master_generic
e1000_ge_auto_rd_done_generic
e1000_reset_mdicnfg_82580
e1000_init_hw_i210
e1000_get_flash_presence_i210
e1000_read_invm_word_i210
//1/bin/Net terminated (SIGSEGV) at 0015:000003D8.
10/14/2015 8:25 AM
post114639
can I get some update about this?
