Forum Topic - First element data corruption in a vector:
Hi all, I noticed that whenever I push_pack() a structure into a vector, there will be incidents when the content in the
 first element always get corrupted. This does not happen consistently but rather randomly.
my structure is defined as follows:
struct myStruct
    uint32_t content1;
    uint32_t content2;
    uint32_t content3;
    uint32_t content4;
Usage is as follows:
class myClass
    public:
        void Update();
        void Retrieve(std::vector<myStruct> &list);
    private:
        std::vector<myStruct> m_list;
void myClass::Update()
    myStruct temp;
    // performing operations to fill up contents in myStruct
    m_list.push_back(temp);
void myClass::Retrieve( std::vector<myStruct> &list)
    for(uint32_t i=0; i<m_list.size(); i++)
        std::cout << m_list[i].content1 << std::endl;
    list = m_list;
I noticed that when I called Retrieve(), the content1 is changed randomly although I have verified that the contents
inside are per what was pushed in in Update(). I am currently using QNX 6.6.0.
May I know what is causing this problem? Thanks.
Re: First element data corruption in a vector
Hi Ong,
This is QNX 4 discussion board, but you asked about QNX 6.6. Please post your question in right forum. It’d be great to
 add a full minimal example (including main() and Makefile) to illustrate the issue.
24 июня 2015 г., в 5:41:32, Ong Di Yong <community-noreply@qnx.com> написал:
the first element always get corrupted. This does not happen consistently but rather randomly.
> struct myStruct
>    uint32_t content1;
>    uint32_t content2;
>    uint32_t content3;
>    uint32_t content4;
> class myClass
>    public:
>        void Update();
>    private:
>    myStruct temp;
>    list = m_list;
> QNX4 Community Support
> http://community.qnx.com/sf/go/post114010
> To cancel your subscription to this discussion, please e-mail qnx4-community-unsubscribe@community.qnx.com
