RE: How to use Phindow to set the Server
06/17/2014 3:51 PM
post110722
Unfortunately Phindows does not have the ability to properly work with a remote Photon display that has a greater
resolution than the Windows screen. You can increase the resolution (size) of Phindows all the way to full screen, but
if the remote display is still too big then Phindows will not be able to scroll the offscreen areas into view.
Try changing to a more dense resolution in Windows, if possible.
Max
From: Олег Большаков [mailto:community-noreply@qnx.com]
Sent: Tuesday, June 17, 2014 11:56 AM
To: qnx4-community@community.qnx.com
Subject: Re: How to use Phindow to set the Server
Hi Vincent,
I've tested Phindows from QNX 6.4.0. This version contains drop-down list to choose screen resolution. Doesn't this
option help you? Can you post here screenshot to illustrate the issue?
17 июня 2014 г., в 5:40, Vincent MAK (LTA) <community-noreply@qnx.com> написал:
> Hi Oleg,
> The phindow come with QNX 6.4.0
> Regards
> Vincent
> VIncent Mak | Principal Engineer | Local Projects & Maintenance |Fare
> Systems Land Transport Authority | Tel: (65) 63962364 | Fax: (65)
> 63962395 | http://www.lta.gov.sg
> Sent: Monday, 16 June, 2014 5:55 PM
> Hi Vincent,
> What version of Phinows do you use? I'll reproduce your case and come back with recommendations.
> Respectfully,
> Oleg
> 13 июня 2014 г., в 6:47:34, Vincent Mak <community-noreply@qnx.com> написал:
>> I'm using Phindow to coonect to QNX server which is fine, but I wish
>> to find out how to adjust such that the application is able to fit into the Phindow.
>> It seem that Phindow is fit to Application. My application image is
>> bigger than phindow and I could not expand my phindow to fit the application presently to capture the whole of the
images in the application.
>> Can the /etc/config/phrelay help? and what service should I run?
>> Regards
>> Vincent
>> QNX4 Community Support
>> http://community.qnx.com/sf/go/post110687
>> To cancel your subscription to this discussion, please e-mail
>> qnx4-community-unsubscribe@community.qnx.com
> http://community.qnx.com/sf/go/post110698
> http://community.qnx.com/sf/go/post110708
http://community.qnx.com/sf/go/post110715
To cancel your subscription to this discussion, please e-mail qnx4-community-unsubscribe@community.qnx.com
