10/07/2013 6:38 AM
post105692
Hi Huwawa,
Sorry for the delay with the answer. Does this problem occur on the specific configuration or on any Core 2 Duo PC? Do
you experience this problem on Core i3/i5/i7 CPU? To get a suggestion and then a solution for you we should reproduce
the problem. Please describe a simple way to reproduce it.
I guess this behavior may be an effect of SMM. If so you can decrease this effect by disabling all unused HW and options
in your BIOS setup.
02.10.2013, в 22:38:01, Huwawa Lugal написал:
> Hi.
> I have problem wiwh timers in qnx4 apps,
> I have simple process, which works with timer triggering every 20ms.
> On old computer (celeron 700MHz) process work fine, on free or stressed system.
> When i run it on on new pc with core 2 duo, something is going wrong.
> Without stress, timers works corect (almost), but when i stress a little system (eg. running some other apps)
> timer (triggering) stay unstable, value is jumpiung 20ms to 0.3mm (random).
> I tested some BIOS settings, eg turn off C1E (blocked speedstep), but without succes.
> How to solve this problem ?
> Thanks.
> H.
> QNX4 Community Support
> http://community.qnx.com/sf/go/post105573
> To cancel your subscription to this discussion, please e-mail qnx4-community-unsubscribe@community.qnx.com
