Forum Topic - Phindows doesn't start Photon when using initial command to start after login in passwd file:
I am using QNX 4.24 server with Phindows 2.0 and Photon since 2001 without any problem. For a specific user, I use to
autostart an application immediately after a succesfull login (in this case "sac" utility in passwd file)
jd213:x:105:100:John Doe:/home/jd213:/usr/bin/sac
I installed QNX 4.25 (last 2011 installation CD bundle) on a new server with creating the same user jd213. If I use /bin
/sh in passwd file, it is OK, Photon is started when I logged in from Phindows. Unfortunately this autostart is not
working anymore when I try any other autostart executables like /usr/bin/sac when I login from Phindows. Phindows Window
 is closing right away without charging Photon. However when I try to login from telnet, "sac" execution is working,
Photon is charged after Phindows login. Curious isn't it ?
Does any of you have ever this problem? If yes, what could be the solution
Thank you
Re: Phindows doesn't start Photon when using initial command to start after login in passwd file
I just realise that when I copy /qnx4/photon (v1.13) over /qnx4/photon (v1.14) it solve the problem. But what could be
wrong in Photon v1.14 that create this issue ? a config file somewhere or something else ?
If someone know the answer...
Hi Louis,
The phlogin utility executes shell command from /etc/passwd to launch script to open new session. This fails with sac
utility.
To automatically start an application immediately after launch Photon add it to $HOME/.photon/phapps:
pterm /usr/bin/sac &
or
phsac &
04.09.2013, в 18:37:33, Louis Francoeur написал:
. But what could be wrong in Photon v1.14 that create this issue ? a config file somewhere or something else ?
> QNX4 Community Support
> http://community.qnx.com/sf/go/post104808
> To cancel your subscription to this discussion, please e-mail qnx4-community-unsubscribe@community.qnx.com
Hi Oleg,
What you explained is true, I can use $HOME/.photon/phapps utility. But I still have a problem:
I want to be able to start a program even if I access from Photon or from Telnet with the same login.
Now with $HOME/.photon/phapps utility active, my program is started from Photon but not from Telnet. If I add my program
 in /etc/passwd (for example: jd213:x:105:100:John Doe:/home/jd213:/bin/program), Telnet is working fine but not Photon
anymore (close the Window right away).
Is there a way to be able to automaticly start a program even from Photon or Telnet without creating 2 different logins
in Photon 1.14 (curiously, it was working in Photon 1.13)?
Thank you
Hi Louis,
New version of software should be handier but I noticed that even small update may lead into trouble. :)
One possible way to get that you ask is adding the following script (fake_sac) instead of sac in /etc/passwd:
#!/bin/sh
if [ $1"m" != "m" ]; then
    exec /bin/sh "$@"
else
    exec /usr/bin/sac
fi
16.09.2013, в 16:53:52, Louis Francoeur написал(а):
> Hi Oleg,
program in /etc/passwd (for example: jd213:x:105:100:John Doe:/home/jd213:/bin/program), Telnet is working fine but not
Photon anymore (close the Window right away).
logins in Photon 1.14 (curiously, it was working in Photon 1.13)?
> Thank you
> http://community.qnx.com/sf/go/post105128
Hi again Oleg,
Now this issue is solved with your last suggestion "fake_sac". I am very happy :)
Thank you very much
Louis
I'm glad to hear it. Making people happy is my work. :)
16.09.2013, в 18:08:33, Louis Francoeur написал:
> Hi again Oleg,
> Thank you very much
> http://community.qnx.com/sf/go/post105131
