Configure Realtek RTL8029AS network adapter on 4.24
08/20/2013 9:08 AM
post104319
I had to use an old backup hard drive on our Precix machine because the one that was installed failed.
However, since that backup was made, the motherboard was replaced. Now, netstart tells me on boot that the resource is
temporarily unavailable. My guess is that the network card needs to be reinstalled/reconfigured but I do not know how to
do it.
Could anyone assist me with this matter?
Yours,
Samuel
Re: Configure Realtek RTL8029AS network adapter on 4.24
08/20/2013 11:37 AM
post104335
Can you post your netstart file as well as your sysinit file and the
output from 'show_pci -v'?
>netstart tells me on boot that the resource is temporarily unavailable.
>but I do not know how to do it.
>Yours,
>Samuel
>QNX4 Community Support
>http://community.qnx.com/sf/go/post104319
>qnx4-community-unsubscribe@community.qnx.com
08/20/2013 11:50 AM
post104336
sysinit:
export TZ=utc00
rtc -l hw
Dev &
Dev.ansi -Q -n 4 &
reopen
Dev.ser &
Dev.par &
emu87 &
tinit -t /dev/con1 -T /dev/con[2-4] &
netboot (could not find a netstart file other than the executable):
f=build/ws.ether1000
show_pci :
IRQ routing = bus=0 slot=2 device=10
Vendor ID = 10ech
Device ID = 8029h
I have the whole log on a txt file, but I cannot copy it from the machine at the moment.
If you need more information, I will try and provide it asap. Thanks!
08/20/2013 12:16 PM
post104342
This is a PCI device, so the driver should auto-detect it, unless the
driver is being started with command line arguments to set the I/O port
and interrupt. You will have to find out how the driver is being started.
On 2013-08-20 11:50 AM, "Samuel Barrette" <community-noreply@qnx.com>
wrote:
>sysinit:
>export TZ=utc00
>rtc -l hw
>Dev &
>Dev.ansi -Q -n 4 &
>reopen
>Dev.ser &
>Dev.par &
>emu87 &
>show_pci :
>Vendor ID = 10ech
>Device ID = 8029h
>at the moment.
>http://community.qnx.com/sf/go/post104336
08/20/2013 12:50 PM
post104346
I found a different sysinit file (which I believe is the one being used):
set -i
export TZ=pst08pdt07,M4.1.0/2,M10.5.0/2
rtc -l hw
Dev &
Dev.ansi -Q -n 10 &
reopen //0/dev/con1
Dev.ser &
Dev.par &
Dev.pty &
mousetrap start
Fsys.floppy &
Pipe &
emu87 &
tinit -T /dev/con* -t /dev/con1 &
netstart
export PATH=&PATH:.:/usr/ucb:/precix/bin
/usr/photon/bin/ph
Does it make any difference? Still getting "Resource temporarily unavailable" message.
I will try to look further, but I am not quite sure how drivers get started in QNX (or how many different ways there are
to do it).
- Sam
08/20/2013 12:53 PM
post104347
There should be a netstart script in the /bin directory, as the network
driver isn't being started in the sysinit script. You can also run 'find /
-name netstart' if the script isn't in the /bin directory.
On 2013-08-20 12:50 PM, "Samuel Barrette" <community-noreply@qnx.com>
>set -i
>rtc -l hw
>Dev &
>Dev.ansi -Q -n 10 &
>reopen //0/dev/con1
>Dev.ser &
>Dev.par &
>Dev.pty &
>mousetrap start
>Fsys.floppy &
>Pipe &
>emu87 &
>netstart
>/usr/photon/bin/ph
>started in QNX (or how many different ways there are to do it).
>- Sam
>http://community.qnx.com/sf/go/post104346
08/20/2013 1:05 PM
post104348
There is one in /etc/config/socket:
export SOCK=$NODE
/bin/slay -f Socket Socklet;
/bin/prefix -D /dev/console >/dev/null 2>&1;
/bin/prefix -A /dev/console >/dev/con1;
/usr/ucb/Socket node$NODE &
/usr/ucb/ifconfig en1 node$NODE up
/usr/ucb/ifconfig lo0 localhost up
/usr/bin/syslogd
It looks like a sample config file to me, but I might be wrong. There are also comments in-between, which I did not
transcribe.
08/20/2013 1:22 PM
post104349
Is this device booting from a hard disk or is it booting from a file
server? If it is booting from a file server, then all the relevant files
will be on the server. You mentioned a ws.ether1000 files, which seems to
indicate that this is a file server.
>export SOCK=$NODE
>/usr/bin/syslogd
>also comments in-between, which I did not transcribe.
>Thanks
>http://community.qnx.com/sf/go/post104348
08/20/2013 1:26 PM
post104350
This boots from an old 60gb hard drive. To my knowledge, this is the only QNX device that we own, so this may act as a
file server -- we do put files on it remotely from the other (windows-based) workstations.
08/20/2013 1:43 PM
post104351
If it is the only QNX4 box that you own, then it won't be a file server.
Have you run 'find / -name netstart*'? Does the command find any files?
>QNX device that we own, so this may act as a file server -- we do put
>http://community.qnx.com/sf/go/post104350
08/20/2013 1:49 PM
post104352
I have netstart* files in:
/etc/config/socket/netstart (which is the one I posted)
/etc/netstart (which is an executable)
/usr/help/product/tcpip/user_guide/files/netstart_f.html
/usr/tcprt/4.24/etc/config/socket/netstart (which is identical to the first one)
08/20/2013 1:51 PM
post104353
The /etc/netstart file sounds like the one we need. It is marked
executable, but should be a shell script, so you should be able to dump
the contents.
>first one)
>http://community.qnx.com/sf/go/post104352
08/20/2013 2:04 PM
post104354
You're right, it's not an executable (my bad).
351 bytes long, appears to be empty (?) in vi. It's just "spaces".
08/20/2013 2:10 PM
post104356
Well maybe that is your problem - the network isn't being started at all!
Try running the following commands at the root command prompt:
slay Net # This is just to make sure that Net isn't running.
Net &
Net.ether1000 &
Socket node1 &
If you now run 'netinfo -L1' you should see network information, unless
you had errors from the previous commands.
If you see the network information, the you can either run
ifconfig en1 ip.address
or
dhcp.client
>http://community.qnx.com/sf/go/post104354
08/20/2013 2:28 PM
post104357
Sounds good. Apparently I need an ip address and/or a route.
Dhcp-client does not exist but ifconfig gives me 0.0.0.0 netmask 0.
08/20/2013 2:39 PM
post104359
Well then you should be able to run "ifconfig en1 ip.address", where
ip.address is a valid ip address on your network.
>http://community.qnx.com/sf/go/post104357
08/20/2013 2:48 PM
post104361
It worked....!
Thank you so much.... definitely couldn't have done it without you.
08/20/2013 2:49 PM
post104362
Good news!
On 2013-08-20 2:48 PM, "Samuel Barrette" <community-noreply@qnx.com> wrote:
>It worked....!
>http://community.qnx.com/sf/go/post104361
