Forum Topic - kill (including with -9) doesn't work any more:
As of a couple weeks ago, kill and kill -9 cannot reliably kill a process. When I do it, it works once, and every
subsequent attempt fails, the only way to stop the process is to reboot the device.
I just tried the trunk-developer build 6629 (London device), which is from today, and it has the same behavior. In my
case it's a python process, under the python interpreter, but for -9 it shouldn't matter - by the book, the process
being killed should not be able to intercept SIGKILL, no matter what it does or how.
(Note that SIGTERM did not work either)
Having to reboot the device many times in a single debugging session is a... hassle, at least.
Can someone please look into this? I can reproduce this behavior on demand and I can provide any logs or other files
from the device, as needed.
Re: kill (including with -9) doesn't work any more
This is the wrong forum - it is for QNX4 issues!.
Hugh Brown
Software Programmer
QNX Software Systems
Office +1 613 591-0931 x 24209
| qnx.com <http://www.qnx.com/>;
>process. When I do it, it works once, and every subsequent attempt fails,
>from today, and it has the same behavior. In my case it's a python
>by the book, the process being killed should not be able to intercept
>demand and I can provide any logs or other files from the device, as
>needed.
>QNX4 Community Support
>http://community.qnx.com/sf/go/post104296
>qnx4-community-unsubscribe@community.qnx.com
