07/29/2013 8:33 AM
post103692
If node 5 only shows one node, then either the netmap file is incorrect or
you are not running "netmap -f" to read the netmap file.
You must not have the same netmap file on every node. On node 1 the netmap
file should have nodes 2,3,4 & 5 in the netmap file, and on node 2 the
netmap file should have nodes 1,3,4 & 5 etc.
On 2013-07-27 7:40 AM, "Leonid Khait" <community-noreply@qnx.com> wrote:
>I tried to follow your recommendations.
>In 5-nodes network on every node I start nameloc with
>nameloc -s i -e i &
>where i - node number.
>Also on every node the same /etc/config/netmap
>refes the addreses of all 5-th nodes of logical 1 and logical 2 networks.
>The result is:
>- on node 1 the command
>#sin net
>show 1,2,3,4, 5 nodes in network.
>- on node 2
>#sin net
>show 1,2,4,5 nodes in network
>- on node 5 the command
>#sin net
>show only single 5 node in network.
>And global names of task from 1-th node can't locate by
>qnx_name_licate(0,"name"...) on node 5.
>QNX4 Community Support
>http://community.qnx.com/sf/go/post103685
>qnx4-community-unsubscribe@community.qnx.com
