03/19/2013 1:55 AM
post99975
it's been many years since I last tried to make a mouse work in QNX4.25.
But as far as I remember I used to do this:
-check if IRQ12 is not shared
- run Mouse/Input in very verbose mode (like five -v) and try to capture type of mouse it detects (PNPsomething)
- then try to add this string to /etc/pnpmouse (or something similar)
- if it's there, try to change given mouse type to some other
- for test if it works fine use Mouse test
Hope it helps,
PKY
> I am evaluating a HP 8300 Elite CMT workstation for use with our QNX 4.25 /
> QNX Windows 4.21B application and have found a problem with the PS/2 mouse:
> the mouse pointer moves around erratically and button clicks are registered
> randomly just by moving the mouse. The same behavior is observed both on text
> mode (VEDIT for example) and in QNX Windows. I have tried both the 1998 Mouse
> driver and the newer Mouse / Input combination driver, with same results.
> Booting the same computer with a Knoppix Live CD gives a working PS/2 mouse,
> so it's not just a hardware issue.
> Has anyone experienced issues like this with QNX 4.25 on new Intel
> mainboards? And what can I do to further troubleshoot this issue?
> Best Regards,
> Christian Friberg
