03/20/2012 6:12 AM
post92199
Hi George,
1. TCPIP SDK 5.1 does not exist. TCPIP SDK 5.0 should be compatible with
RT 5.1.
2. In general, following sequence would be enough to update the TCPIP RT
on remote machine:
- copy directory /usr/tcprt/5.10 to your remote machine
- on the remote machine run tcpip.switch script:
# /usr/tcprt/5.10/switch.tcpip 5.10
The switch.tcpip script will setup all required symbol links.
Please let me know about your results with TCPIP 5.1 RT.
Pavel
> The process Tcpip (version 5.0) crashed produced a .dmp file also.
> I have downloaded the new product suite, and made the update.
> Regarding to this I have two questions:
> 1) only TCPIP RunTime was updated from 5.0 to 5.1.
> TCPIP SDK has still the version 5.0. Is the version 5.1 for TCPIP-SDK
> also available? Or, run the programs stable compiled with SDK 5.0 under RT 5.1?
> 2) I would need to perform the update on a remote machine which is on a
> distance of 800 km. Therefore it is difficult to insert a CD into the remote
> machine and boot from the CD. Could sombody help me, which files,
> directories do I have to copy to the remote machine, and which program do I
> have to invoke, when I cannot insert a CD, and therefore I cannot boot from
> the CD on the remote machine.
> Thanks in advance for the replies,
> QNX4 Community Support
> http://community.qnx.com/sf/go/post92178
