Pavel Kozlov(deleted)
Re: Auto detect of PS2 Style Mouse
03/01/2012 4:12 AM
post91865
Hi Larry,
In your situation Photon restart is not required. You can simply restart
the Input manager. I would recommend you the following sequence:
-when you start Photon, run Input manager only for a keyboard. If you
use script ph then edit /etc/config/trap/input.$NODE file. It should
contain only: kbd fd -d /dev/kbd
- connect mouse
- manually start Input manager for a PS/2 mouse by the following command:
#Input ps2 -r kb -2 &
- disconnect mouse
- kill Input manger for mouse.
Attaching simple script. You can use it to automate start/stop/restart
of the Input manager for a PS/2 mouse (steps 3-5).
Pavel
> We have an embedded system that we plug a keyboard and mouse into only when we need to debug.
The OS always detects the keyboard when it is plugged in. However, plugging in the mouse always requires a reboot for
Photon to detect it.
> Is there any way we can get the PS/2 mouse auto detected without requiring a reboot?
> QNX4 Community Support
> http://community.qnx.com/sf/go/post91838
Erick Muis
Erick Muis
03/01/2012 11:04 AM
post91876
> need to debug. The OS always detects the keyboard when it is plugged in.
> However, plugging in the mouse always requires a reboot for Photon to detect
> it.
> reboot?
Hi Larry,
Pavel mentioned a way to do this, however I want to emphasize that PS/2 does _NOT_ hotplugging, and depending on the
controller it is not unheard of for PS/2 controllers to become damaged due to hotplugging.
http://en.wikipedia.org/wiki/PS/2_connector#Hotplugging
You'd be far better off using a USB peripherals and the devu-mouse and devu-kbd drivers instead along with the Input
driver. You'd need to write a simple program or script that monitors for the presense of /dev/usbkbd0 and /dev/
usbmouse0 and then start the Input driver to run when those entries are present. You'd have to write the program,
however it would be far easier than replacing broken hardware should that ever happen.
Best regards,
Erick.
