Forum Topic - Touch Screen Controller:
I'm planning to use  3200L 32" Interactive Digital Signage Touch Display with IntelliTouch Plus 2510/2515 Dual Touch
Controllers or
IntelliTouch/SecureTouch 2701RSU Dual Serial/USB Controller
Both of them support Full IntelliTouch SmartSet protocol Operating Mode.
Will Suite 2011 QNX4 Input program support IntelliTouch SmartSet protocol ?
http://www.elotouch.com/products/Touchscreens/IntelliTouch/Plus/c251xSeries.asp or
http://www.elotouch.com/Products/Touchscreens/IntelliTouch/c2701rsu.asp
Thank you.
Re: Touch Screen Controller
> IntelliTouch Plus 2510/2515 Dual Touch Controllers or
> asp or
> Thank you.
The serial driver supports the 10-byte protocol that the smartset controller uses.  The Intellitouch I recall has a
configurable jumper that will allow you to set it to use the 10-byte protocol as well.
The other option is to use the USB interface and the use the USB drivers located here:
http://www.qnx.com/download/feature.html?programid=17049
Suite 2011 already includes those binaries.
Best regards,
Erick
