Forum Topic - issue with copying/ftp files in virtual environment: (9 Items)
I have recently setup a virtual environment with four quest QNX 4.25 O/S and when I am trying to copy files between
NODES it errors out stating:
cp: write (//1///[filename]): Interrupted function call
cp: close (//1///[filename]): Bad file descriptor
When I FTP I get I get similiar results.....it just hangs and then finally times out.
Any assistance I can get to try and get this resolved would be great.
Hi Brad,
Please, send us output of following commands (from two QNX nodes):
# sin in > sin_in.txt
# sin ar > sin_ar.txt
# sin ver > sin_ver.txt
# netmap > netmap.txt
# netinfo -l > netinfo.txt
What is your virtual environment?
when I am trying to copy files between NODES it errors out stating:
times out.
> QNX4 Community Support
> http://community.qnx.com/sf/go/post90575
Re: issue with copying/ftp files in virtual environment
Hi Oleg,
I have attached the files as requested---hope this helps.
And the Virtual Environment we are using is VMware vSphere 5.0
Thank you,
Brad Anderson
INTERPRO Technology, Inc.
Office: 248-650-8695
Sent: Wednesday, December 14, 2011 10:38 AM
To: qnx4-community
Subject: issue with copying/ftp files in virtual environment
Hi Brad,
> and
times out.
http://community.qnx.com/sf/go/post90619
Attachment: Text netinfoNODE3.txt 1.36 KB Text netinfoNODE4.txt 1.36 KB Text netmapNODE3.txt 282 bytes Text netmapNODE4.txt 298 bytes Text sin_arNODE3.txt 1 KB Text sin_arNODE4.txt 1 KB Text sin_inNODE3.txt 360 bytes Text sin_inNODE4.txt 360 bytes Text sin_verNODE3.txt 1.07 KB Text sin_verNODE4.txt 1.07 KB
Hi Brad,
I see nothing wrong in your QNX configuration. Unfortunately, we don't use here
the VMware vSphere 5.0. Can you test your QNX guests with VMWare Workstation?
> Hi Oleg,
> Thank you,
> Brad Anderson
> From: Oleg Bolshakov
> To: qnx4-community
> Hi Brad,
> Respectfully,
> Oleg
> > and
> times out.
> http://community.qnx.com/sf/go/post90629
Hi Oleg,
Thanks for taking a look at this.     No cannot test with VMWare
Workstation.     If you can think of anything else on this just let me know.
Thank you,
Brad Anderson
Sent: Friday, December 16, 2011 3:07 AM
To: qnx4-community
Subject: Re: issue with copying/ftp files in virtual environment
Hi Brad,
here
Workstation?
> Hi Oleg,
> Thank you,
> Brad Anderson
> To: qnx4-community
> Hi Brad,
> Respectfully,
> Oleg
> > and
> > finally
> times out.
http://community.qnx.com/sf/go/post90657
Oleg....
If I can asked another quick question............when I try and DITTO across
the virtual nodes I receive an error message that comes back and says "
rem_reply: sender in wrong state" and then in a few seconds says "PROC: lost
reply across net, freeing reply_blk local pid 00F6"
This is another issue I need to get resolved so not sure if both would be
related at all or not.
Let me know if you can.
Brad Anderson
Sent: Friday, December 16, 2011 8:40 AM
To: qnx4-community
Hi Oleg,
Thank you,
Brad Anderson
To: qnx4-community
Hi Brad,
here
Workstation?
> Hi Oleg,
> Thank you,
> Brad Anderson
> To: qnx4-community
> Hi Brad,
> Respectfully,
> Oleg
> > and
> > finally
> times out.
Hi Brad,
I think that all issues depend on network.
It's only my assumption, but try to test all previous Net.e1000 drivers. The
driver was seriously updated. May be the old driver will work better on your
environment.
http://community.qnx.com/sf/frs/do/viewRelease/projects.qnx4/frs.network_drivers.net_e1000
> Oleg....
> Brad Anderson
> From: Brad Anderson
> To: qnx4-community
> Hi Oleg,
> Thank you,
> Brad Anderson
> To: qnx4-community
> Hi Brad,
> here
> Workstation?
> Respectfully,
> Oleg
> > Hi Oleg,
> > Thank you,
> > Brad Anderson
> > To: qnx4-community
> > Hi Brad,
> > Respectfully,
> > Oleg
> > > and
> > > finally
> > times out.
> > QNX4 Community...
Hi Oleg,
I have tried all previous Net.e1000 drivers and still no luck on getting
this to work-----any other ideas by anyone that I can try to getting this to
work?
Thanks......Brad
Sent: Monday, December 19, 2011 3:18 AM
To: qnx4-community
Hi Brad,
environment.
> Oleg....
> across
> lost
> Brad Anderson
This sounds like something to do with your virtual environment as the
driver works just fine in a standalone environment. I run QNX4 under
VMWare Fusion on my Mac using bridged networking and it works perfectly.
The only difference is that VMWare Fusion uses the Net.ether2100 driver.
Hugh Brown
QNX Software Systems Limited
175 Terence Matthews Crescent,
Ottawa. ON. K2M 1W8.
Telephone: 613-591-0931
On 12-01-03 5:06 PM, "Brad Anderson" <community-noreply@qnx.com> wrote:
>Hi Oleg,
>to
>work?
>Thanks......Brad
>To: qnx4-community
>Hi Brad,
>The
>your
>environment.
>rivers.net_e1000
>Respectfully,
>Oleg
>> Oleg....
>> across
>> lost
>>be
>> Brad Anderson
>http://community.qnx.com/sf/go/post90824
