Forum Topic - Hardware question about TB-ATOM-N450:
I have encountered serious problem with computer mentioned in topic. My task is to install the QNX on the machine, but I
 am unable to make hard drives working. I have tried 3 different hard drives (two of them uses IDE interface, last one-
SATA). I have to mention that, I use IDE to SATA adapter, so each of one HDD drives is plugged in via the adapter to
SATA port on mainboard. Unfortunately none of them is detected by BIOS. The only device that is detected properly is my
CD/DVD-ROM. I have no idea why it is not working.
I will appreciate any comments, or clues.
Hi Hieronim,
If the BIOS can't detect hard drives then this is not QNX issue. Please, check
carefully that you have plugged and powered drives correctly. Ask your
hardware vendor how to connect hard drive to the board.
> Hello,
is to install the QNX on the machine, but I am unable to make hard drives
last one- SATA). I have to mention that, I use IDE to SATA adapter, so each of
one HDD drives is plugged in via the adapter to SATA port on mainboard.
detected properly is my CD/DVD-ROM. I have no idea why it is not working.
> QNX4 Community Support
> http://community.qnx.com/sf/go/post90142
