driver for Intel Pro/1000 GB nic card
02/25/2008 2:17 PM
post5242
I have a platform for development that only supports PCIe, and I need to install a nic card on this machine. I got an
Intel Pro/1000 Gb nic card, and I could not run the installation on my QNX (while running the make install as suggested
from the README file, QNX choke). The enclosed is the zip file that includes the source code comes from the CD.
RE: driver for Intel Pro/1000 GB nic card
02/25/2008 2:45 PM
post5243
Why are you trying to install a Linux driver under QNX?
From: Liang-Min Wang [mailto:liang-min.wang@intel.com]
Sent: Monday, February 25, 2008 2:17 PM
To: qnx4-community
Subject: driver for Intel Pro/1000 GB nic card
install a nic card on this machine. I got an Intel Pro/1000 Gb nic card, and
as suggested from the README file, QNX choke). The enclosed is the zip file
QNX4 Community Support
http://community.qnx.com/sf/go/post5242
Re: driver for Intel Pro/1000 GB nic card
02/25/2008 3:02 PM
post5245
There is no support of PCIe driver from QNX website. Since the driver installation CD provides the source code, I
thought there may be a way that I could re-compiler under QNX development suite to generate a driver for QNX. Is this
feasible? If so, how could I do that?
Larry
02/25/2008 3:11 PM
post5246
The Intel PRO/1000 PCIe is supported under QNX. The driver is
devn-i82544.so.
Sent: Monday, February 25, 2008 3:03 PM
To: qnx4-community
Subject: Re: driver for Intel Pro/1000 GB nic card
installation CD provides the source code, I thought there may be a way that
QNX. Is this feasible? If so, how could I do that?
Larry
http://community.qnx.com/sf/go/post5245
02/25/2008 3:58 PM
post5250
Thanks. I will give it a try.
Larry
Sent: Monday, February 25, 2008 3:11 PM
To: qnx4-community
Subject: RE: driver for Intel Pro/1000 GB nic card
devn-i82544.so.
To: qnx4-community
that
Larry
http://community.qnx.com/sf/go/post5246
02/26/2008 9:54 AM
post5266
I found the driver under x86/lib/dll directory over my QNX RTOS, but the
system still doesn't pickup the driver, and no Ethernet connection,
therefore I could not activate my OS. Is there any document how to setup
the connection? I have another system installed with the Neutrino
(different nic card), and it requires no setup to connect to Ethernet.
Liang-Min Wang
To: qnx4-community
devn-i82544.so.
To: qnx4-community
that
Larry
02/26/2008 9:59 AM
post5267
It might be that the device ID for your chipset is not in the enumeration
files. Could you please post the output from 'pci -v'? Also, you can try
starting the driver manually as follows:
slay io-net dhcp.client
io-net -di82544 -ptcpip
dhcp.client
Sent: Tuesday, February 26, 2008 9:55 AM
To: qnx4-community
Liang-Min Wang
To: qnx4-community
devn-i82544.so.
To: qnx4-community
that
Larry
http://community.qnx.com/sf/go/post5266
02/26/2008 11:52 AM
post5279
The enclosed is the output for 'pci -v ' and the output from ifconfig.
When I ran slay io-net dhcp.client, the system complains
'unable t find process dhcp.client'
Larry
Sent: Tuesday, February 26, 2008 9:59 AM
To: qnx4-community
enumeration
dhcp.client
To: qnx4-community
Liang-Min Wang
To: qnx4-community
devn-i82544.so.
To: qnx4-community
that
Larry
http://community.qnx.com/sf/go/post5267
02/26/2008 12:59 PM
post5280
Please try the attached experimental driver and let me know if it works. If
you place the driver in /tmp, you can start it as follows:
io-net -d/tmp/devn-i82544.so -ptcpip
dhcp.client
Sent: Tuesday, February 26, 2008 11:52 AM
To: qnx4-community
Larry
To: qnx4-community
enumeration
dhcp.client
To: qnx4-community
Liang-Min Wang
To: qnx4-community
devn-i82544.so.
To: qnx4-community
that
Larry
http://community.qnx.com/sf/go/post5279
02/26/2008 2:40 PM
post5287
I tried the new .so file, some improvement, but still have no ip-address
After the two commands, I type ifconfig; this time, I got en0 detected
with mac address but no ip address, so I ran the network configuration.
As soon as I chose the DHCP, the system complains:
netmanager error: could not configure DHCP on interface en0
netmanager error: dhcp.client: could not reach DHCP server on interface
en0
Larry
Sent: Tuesday, February 26, 2008 12:59 PM
To: qnx4-community
If
dhcp.client
To: qnx4-community
Larry
To: qnx4-community
enumeration
dhcp.client
To: qnx4-community
Liang-Min Wang
To: qnx4-community
devn-i82544.so.
To: qnx4-community
that
Larry
http://community.qnx.com/sf/go/post5280
02/26/2008 2:46 PM
post5288
You cannot use the GUI to configure the interface, as you have slayed io-net
and re-started it. Please can you post the output from nicinfo after
starting the driver. I presume that you do have a DHCP server on your
network?
Sent: Tuesday, February 26, 2008 2:41 PM
To: qnx4-community
en0
Larry
To: qnx4-community
If
dhcp.client
To: qnx4-community
Larry
To: qnx4-community
enumeration
dhcp.client
To: qnx4-community
Liang-Min Wang
To: qnx4-community
devn-i82544.so.
To: qnx4-community
that
Larry
QNX4 Community...
02/26/2008 3:36 PM
post5296
Thanks, my issue is resolved now. The new .so does resolve the issue. My
last issue is related to network connection issue.
Larry
Sent: Tuesday, February 26, 2008 2:46 PM
To: qnx4-community
io-net
network?
To: qnx4-community
en0
Larry
To: qnx4-community
If
dhcp.client
To: qnx4-community
Larry
To: qnx4-community
enumeration
dhcp.client
To: qnx4-community
Liang-Min Wang
To: qnx4-community
devn-i82544.so.
To: qnx4-community
that
Larry
QNX4 Community...
