Re: QNX post-installation problem
06/02/2011 12:20 AM
post86373
Hi Hieronim,
You've posted your question in the QNX4 discussion board, but you asked
about the QNX6. Please, post the question again in the QNX Momentics
Getting Started.
I think that your problem is graphics controller. Please replace it with
another one if it possible.
> Hello,
> I am new to QNX. I`ve installed the system, but I`m unable to run it.
> It doesn`t boot from hard disk(i have tried IDE and SATA) and neither
> from CD( i mean "live qnx"). Message I get every time i`m trying to
> run the system is:
> Press the space bar to input boot options or D to disable DMA...
> Trying SATA ahci. Scanning for devices...
> xpt_configure: ahci SIM attach failure
> Trying EIDE. Scanning for devices...
> ..found 2 devices
> Detected USB. Scanning for devices...
> Trying SATA mvSata. Scanning for devices...
> xpt_configure: No mvSata interfaces found
> Generating helpviewer search index
> Copied "/usr/photon/config/crtc-settings" to
> "/etc/system/config/crtc-settings" Starting extra run commands
> login:
> At this point system hangs, nothing is showing up when i am typing (I
> tried "root" then enter, nothing happened). I`d like to add one more
> information: during booting, the system enters to graphical mode (i
> can see mouse cursor on black background) for a while, then goes back
> to text mode to show the messages I`ve posted above.
> I will appreciate any clues.
> QNX4 Community Support
> http://community.qnx.com/sf/go/post86360
08/10/2011 8:59 PM
post87997
I know its the wrong forum but the problem is you graphics driver. What you need to do is press the space bar during
startup hen select F1 for safe modes.
Select the F3 option and then press enter then enter again.
Once you are at the command prompt login in with root.
Type crttrap clear and press enter. It will clear the graphis driver so it will look again during the next boot.
Then type shutdown -f and press enter. The system wil reboot and when it gets to the graphics driver start it will
search for the correct driver and then continue with asking you to accept the driver or test it either one is correct.
Press accept and it should go to the graphics screen.
Good luck
