06/01/2011 2:22 PM
post86350
Good afternoon,
I have an interesting issue with the ifconfig command. Currently, i'm running QNX 4 and I set up the networking which
seems to be running fine. Interestingly enough, when the CPU boots up, it tells me that 'ifconfig: not found.'
However, I can still use the command ifconfig to set up the network. QNX does not seem to recognize it on the boot up.
I checked the sysinit file and everything 'seems' normal. Should I attempt to post up the sysinit? anyone have any
ideas what this problem is?
Thanks again.
