Re: How do I get devu-kbd working?
04/15/2011 11:18 AM
post85047
Hi Graham,
Unfortunately under QNX4 you cannot use a USB keyboard in console mode (unless you are using BIOS emulation). Dev.con
does not support USB devices so it has no knowledge that a keyboard is attached.
So your best bet would be to just use the BIOS emulation and if you need USB support, get a PCI card and when you start
io-usb you can specify which controller you are using so the BIOS emulation is not disabled (see pci index in the devu-*
driver). This should work, however I have never tried it.
Best regards,
Erick
> I've installed the latest QNX 4.25 USB stack (2010-07-07), and started "io-usb
> " and "devu-kbd". The "usb" utility indicates that my USB keyboard is
> connected, but it still doesn't seem to be working. What am I missing?
> Note that I'm using the character-mode console only, not Photon.
> I'm not sure whether it matters, but I did plug in the keyboard before
> starting devu-kbd.
> I've used BIOS emulation successfully before, but of course this stops working
> as soon as "io-usb" is started.
