Re: wd debugger source files location
10/12/2010 9:09 AM
post70240
On Tue, 2010-10-12 at 09:06 -0400, David Bo Jensen wrote:
> > You can use 'directory' gdb command to add additional
> > directories gdb will search for source files.
> Sounds great but I do not have gdb. Insted I have wd watcom debugger.
> Is gdb better? Where can I get it for qnx4?
oops, sorry.
I know nothing about wd debugger (nor qnx4). Sorry for introducing the
confusion.
10/12/2010 9:16 AM
post70243
Problem solved.
The wd has a menu item used for that purpose.
File-Source Path
