Re: installation of QNX4-USB-2.0-20051114.tgz
09/30/2010 9:52 AM
post69159
First of all check to see whether Dosfsys is already running. If it is, then
slay it. When you run Fsys.umass, it will create a /dev/hd* entry. Then
perform a 'mount -p /dev/hd*'. You should then see a /dev/hd*t11. Rather
than running Dosfsys, use Fatfsys as follows: Fatfsys c=/dev/hd*t11.
You should now have a /dos/c entry.
On 10-09-30 9:42 AM, "David Bo Jensen" <community-noreply@qnx.com> wrote:
> Thanks ofcourse
> I guess that all the files in the bin directory of the archive have to be
> copied to the /bin directory.
> I run
> #io-usb
> #Fsys.umass
> It all looks fine, then I tried to run
> #Dosfsys c=/dev/usb
> Dosfsys: # cannot attach prefix - /dos: File exists
> #mount /dev/usb usb
> mount: mount( ) of /dev/usb failed: Function not implemented
> Why can't I mount?
> I have one floppy disk in other words a /dos/a
> QNX4 Community Support
> http://community.qnx.com/sf/go/post69156
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
