Virgil Anuichi(deleted)
resource manager. i2c - possible file system.
09/27/2010 5:03 PM
post68706
Trying to think of the best way to implement the i2c driver, in general a serial driver that would/may get a device as a
"file". For instance /dev/i2c/slave1 .. n.
_io_read / write would be common in terms of the actual code, however, I'd need to know which device/slave is, in fact,
accessed.
I'm just starting working with qnx and I'm trying to think of the best strategy to design an i2c driver.
How would i know, inside "io_read", which slave is this call about? Or should I even care?
I'd need this since each slave has its own address and the decision to access one piece of hw or another depends on this
address. I could go further and split this up into "internal addresses" but the idea stays the same.
I understand I can access pid/gid inside _io_read, but how do I make the connection to the actual slave? Should I save
these values when open is called and this way make the connection with the slave? But even in this case, how do I know
the actual path name? Is it passed into io_open or io_read?
A small example:
open (/dev/i2c/slave1) and open(/dev/i2c/slave2).
Then _io_read would be called for either of them.
slave1 and slave2 have different addresses so how would I know if io_read was called for the opened slave1 or slave2?
Virgil
