Forum Topic - pthread_cond_timewait returns errorcode EBUSY:
I have some applications, which return at call of pthread_cond_timewait the errorcode 16 (EBUSY).
In the manual its written, that this errorcode is for this function not possible.
The case is, when I call pthread_cond_wait() instead of pthread_cond_timewait() than everything is fine.
So I would think, the condition variable and mutex variable, would be passed wright.
And the third parameter (abstime) I exemined by call of pthread_cond_timewait looks well either.
Could anyone give me tip?
here the code snipped:
static OS_ErrorCode os_waitForCondition(OS_Event* ev, OS_NanoSec durationTime)
   //neu:
   pthread_mutex_lock(&waitMutexLock);
   volatile int err;
   struct timespec spec;
   OS_NanoSec targetTime;
   if (!ev)
      tPrintf(TRC_FAULT | TRC_COSA, "%s: Invalid parameter", __FUNCTION__);
      //neu:
      pthread_mutex_unlock(&waitMutexLock);
      return OS_InvalidParam;
   pthread_mutex_lock((pthread_mutex_t*) &(ev->mutex));
   if (ev->signaled)
      if (!ev->manualReset)
         ev->signaled = OS_FALSE;
      pthread_mutex_unlock(&ev->mutex);
      //neu:
      return OS_Success;
   if (durationTime != OS_INFINITE)
      OS_ErrorCode r = os_getCurrentTime(&targetTime);
      if (r != OS_Success)
         //neu:
         return r;
      targetTime += durationTime;
      if(targetTime > 1000000000ULL)
    	  spec.tv_sec = /*(time_t)*/ (targetTime / 1000000000ULL);
      else
    	  spec.tv_sec = 0;
      spec.tv_nsec = (long) (targetTime % 1000000000ULL);
/*      clock_gettime(CLOCK_REALTIME, &spec);
      spec.tv_sec += 5;
      spec.tv_nsec = 0;
      err = pthread_cond_timedwait((pthread_cond_t *)&(ev->cond), (pthread_mutex_t *)&(ev->mutex), (const struct timespec*)&spec);
   else
      err = pthread_cond_wait(&ev->cond, &ev->mutex);
   switch (err)
      case 0:
         pthread_mutex_unlock((pthread_mutex_t*) &ev->mutex);
         //neu:
         return OS_Success;//signaled!
      case ETIMEDOUT:
         //neu:
         return OS_Timeout;
      default:
         tError(TRC_FAULT | TRC_COSA, err, "%s", __FUNCTION__);
         break;
   //neu:
   return OS_Error;
With best regards
