Mounting DVD - error - "Resource termporarily unavailable"
06/29/2010 8:57 AM
post58031
I am trying to mount a DVD on QNX 4.25, the DVD drive is connected via SATA cable and the motherboard sees it as EIDE.
Using 'show_pci - v' I found the hardware information and run the following commands:
# ls /dev
con1
# Fsys.atapi atapi irq=10,vid=0x8086,did=0x2920,pci=0 &
65 running Fsys.atapi
# Path=0 - Intel 82801HB SA
target=0 lun=0 CD-ROM(5) - Optiarc DVD+-RW AD-7200S Rev: 101A
# ls /dev
cd0
con1
// Option 1
# Iso9660fsys -s -m &
72 running Iso9660fsys
# mount -t iso9660 /dev/cd0 /cd
Error mounting /cd (Resource temporarily unavailable)
// Option 2
# Iso9660fsys /cd=/dev/cd0 &
// Nothing happens
With Option 1 the DVD drive starts to spin then the error shows up. What am I doing incorrectly?
Re: Mounting DVD - error - "Resource termporarily unavailable"
06/29/2010 8:58 AM
post58032
Sorry there is an error in the last message. Option 2 should look like this:
// Option 2
# Couldn't add '/cd'
06/29/2010 9:04 AM
post58033
After running Iso9660fsys, if you do an ls of /cd, do you see anything? You
don't have to mount the CD/DVD.
> cable and the motherboard sees it as EIDE. Using 'show_pci - v' I found the
> # ls /dev
> con1
> # ls /dev
> cd0
> con1
> // Option 1
> // Option 2
> // Nothing happens
> doing incorrectly?
> QNX4 Community Support
> http://community.qnx.com/sf/go/post58031
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
06/29/2010 9:19 AM
post58035
No, there is no /cd directory
> > # ls /dev
> > con1
> > # ls /dev
> > cd0
> > con1
> > // Option 1
> > // Option 2
> > // Nothing happens
> I
> > doing incorrectly?
> K2M 1W8
06/29/2010 9:21 AM
post58036
Try slaying Iso9660fsys and then re-run it without any options. You should
then see a /cd0 directory. You can run an ls /cd0 to see the DVD.
>>> # ls /dev
>>> con1
>>> # ls /dev
>>> cd0
>>> con1
>>> // Option 1
>>> // Option 2
>>> // Nothing happens
>> I
>>> doing incorrectly?
>> K2M 1W8
> http://community.qnx.com/sf/go/post58035
K2M 1W8
06/29/2010 9:27 AM
post58038
Here's my screen:
69 running Fsys.atapi
# Iso9660fsys &
# No drives defined
You should
> SATA
> the
> >>> # ls /dev
> >>> con1
> >>> # ls /dev
> >>> cd0
> >>> con1
> >>> // Option 1
> >>> // Option 2
> >>> // Nothing happens
> am
> >> I
> >>> doing incorrectly?
> >> K2M 1W8
> K2M 1W8
06/29/2010 9:41 AM
post58041
Can you run 'dcheck /dev/cd0'? Does that work?
On 10-06-29 9:27 AM, "Jagdish Bhati" <community-noreply@qnx.com> wrote:
> Here's my screen:
> # Iso9660fsys &
> # No drives defined
>> SATA
>> the
>>>>> # ls /dev
>>>>> con1
>>>>> # ls /dev
>>>>> cd0
>>>>> con1
>>>>> // Option 1
>>>>> // Option 2
>>>>> // Nothing happens
>> am
>>>> I
>>>>> doing incorrectly?
>>>> K2M 1W8
>> K2M 1W8
> QNX4 Community...
06/29/2010 10:06 AM
post58059
# dcheck /dev/cd0
Read check of /dev/cd0 without bad block marking,
starting at block 1 for the remainder of the disk.
Checking 8168512 blocks (4084256K)
Disk is OK
// This DVD works fine on my Linux workstation and on a XP machine.
> > Here's my screen:
> > # Iso9660fsys &
> > # No drives defined
> You
> >> SATA
> >> the
> >>>>> # ls /dev
> >>>>> con1
> >>>>> # ls /dev
> >>>>> cd0
> >>>>> con1
> >>>>> // Option 1
> >>>>> // Option 2
> >>>>> // Nothing happens
> What
> >> am
> >>>> I
> >>>>> doing incorrectly?
> >>>> K2M 1W8
06/29/2010 10:14 AM
post58065
Just a note..this machine's DVD+RW drive works fine (reading & burning) in other operating systems and can boot. So I don't think this is hardware related.
> # dcheck /dev/cd0
> Disk is OK
> > > Here's my screen:
> > > # Iso9660fsys &
> > > # No drives defined
> should
> > You
> > >> SATA
> found
> > >> the
> > >>>>> # ls /dev
> > >>>>> con1
> > >>>>> # ls /dev
> > >>>>> cd0
> > >>>>> con1
> > >>>>> // Option 1
> > >>>>> // Option 2
> > >>>>> // Nothing happens
> > What
> > >> am
> > >>>> I
> > >>>>> doing incorrectly?
06/29/2010 10:15 AM
post58066
Well if you can 'dcheck' the /dev/cd0, then I don't see why Iso9660fsys
can't see the device. Can you post the output from 'sin' and 'sin ver'?
On 10-06-29 10:06 AM, "Jagdish Bhati" <community-noreply@qnx.com> wrote:
> # dcheck /dev/cd0
> Disk is OK
>>> Here's my screen:
>>> # Iso9660fsys &
>>> # No drives defined
>> You
>>>> SATA
>>>> the
>>>>>>> # ls /dev
>>>>>>> con1
>>>>>>> # ls /dev
>>>>>>> cd0
>>>>>>> con1
>>>>>>> // Option 1
>>>>>>> // Option 2
>>>>>>> // Nothing happens
>> What
>>>> am
>>>>>> I
>>>>>>> doing incorrectly?
06/29/2010 10:36 AM
post58079
# sin
SID PID PROGRAM PRI STATE BLK CODE DATA
1 64 //1/hd/bin/Fsys.atapi 22r RECV 0 90k 188k
1 89 //1/hd/bin/Iso9660fsys 10o REPLY 0 28k 57k
1 91 //1/ram/sin 10o REPLY 1 45k 32k
# sin ver
PROGRAM NAME VERSION DATE
//1/hd/bin/Fsys.atapi atapi 4.25G Jul 06 2009
**There was no Iso9660fsys in the 'sin ver' output.
> > # dcheck /dev/cd0
> > Disk is OK
> >>> Here's my screen:
> >>> # Iso9660fsys &
> >>> # No drives defined
> should
> >> You
> >>>> SATA
> found
> >>>> the
> >>>>>>> # ls /dev
> >>>>>>> con1
> >>>>>>> # ls /dev
> >>>>>>> cd0
> >>>>>>> con1
> >>>>>>> // Option 1
> >>>>>>> 72 running...
06/29/2010 10:44 AM
post58083
For some reason your Iso9660fsys is reply blocked on Proc. Are you starting
Fsys.atapi and Iso9660fsys manually or in your sysinit file or boot image?
You must allow time between starting the disk driver and Iso9660fsys,
otherwise Iso9660fsys won't see the DVD drive.
On 10-06-29 10:36 AM, "Jagdish Bhati" <community-noreply@qnx.com> wrote:
> # sin
> 32k
> # sin ver
>>> # dcheck /dev/cd0
>>> Disk is OK
>>>>> Here's my screen:
>>>>> # Iso9660fsys &
>>>>> # No drives defined
>> should
>>>> You
>>>>>> SATA
>> found
>>>>>> the
>>>>>>>>> # ls /dev
>>>>>>>>> con1
>>>>>>>>> # Fsys.atapi atapi irq=10,vid=0x8086,did=0x2920,pci=0...
06/29/2010 11:10 AM
post58086
I am doing this manually. I just re-did it giving it a good amount of time this time the DVD drive started spinning but
it still output:
Could I have loaded the disk driver incorrectly? Could that be the source of the blocked reply on Proc.
> > # sin
> 188k
> > 32k
> > # sin ver
> >>> # dcheck /dev/cd0
> >>> Disk is OK
> >>>>> Here's my screen:
> >>>>> # Iso9660fsys &
> >>>>> # No drives defined
> >> should
> anything?
> >>>> You
> >>>>>>>>> I am trying to mount a DVD on QNX 4.25, the DVD...
06/29/2010 11:15 AM
post58088
I will only be able to tell you this if you post the full output of
'show_pci -v'.
> this time the DVD drive started spinning but it still output:
>>> # sin
>> 188k
>>> 32k
>>> # sin ver
>>>>> # dcheck /dev/cd0
>>>>> Disk is OK
>>>>>>> Here's my screen:
>>>>>>> # Iso9660fsys &
>>>>>>> # No drives defined
>>>> should
>> anything?
06/30/2010 12:58 PM
post58224
Hugh I have posted here twice and you have replied very quickly both times. Thank you very much. Okay now on to the
problem at hand. The 'Fsys.atapi' and 'Iso9660fsys' binaries and commands were fine. The source of the problem was
that the script booting QNX on the machine had an incorrect 'prefix' command. This was causing problems mounting
anything (I didn't even think to check this).
I know this is not a very clear solution, so I will closely watch the entire boot process (specifically /etc/config/
sysinit) to find the culprit. I will post any findings.
Thanks again Hugh
> 'show_pci -v'.
> of
> >>> # sin
> >> 188k
> 57k
> >>> 32k
> >>> # sin ver
> >>>>> # dcheck /dev/cd0
> >>>>> Disk is OK
> >>>>>>> Here's my screen:
