Forum Topic - Networking issues with QNX 4 :
Good afternoon all,
  I have recently installed the latest QNX iso from the website and am currently trying configure the networking.  I
have successfully been able to ping internally to the box, but when I try it to an outside device, say, a external
harddrive w/ ethernet ports, I get nothing.  I figure it could be an issue where I might have to configure my network
card? but I am not too sure. I would really appreciate any help towards this.
Thank you,
~Julian
Re: Networking issues with QNX 4
If you can post the output from 'show_pci -v' we should be able to tell you
how to start your network adapter.
On 10-05-13 2:05 PM, "Julian Babel" <community-noreply@qnx.com> wrote:
> Good afternoon all,
> currently trying configure the networking.  I have successfully been able to
> external harddrive w/ ethernet ports, I get nothing.  I figure it could be an
> issue where I might have to configure my network card? but I am not too sure.
> Thank you,
> ~Julian
> QNX4 Community Support
> http://community.qnx.com/sf/go/post54592
Kanata, Ontario, Canada.
K2M 1W8
Thank you Mr Brown for your help.
  I tried to copy the contents of the file but when I did "nettrap -vvvvvv start net.file 2>&1" following the show_pci -
v command.. I get a "tr164a: TR hardware init function failure code=0008" error.  My cpu then freezes and I have to
reboot.  Any suggestions?
OK, just run 'show_pci' and send me the Vendor and Device IDs that show up
for Network.
> start net.file 2>&1" following the show_pci -v command.. I get a "tr164a: TR
> have to reboot.  Any suggestions?
> http://community.qnx.com/sf/go/post54596
K2M 1W8
Ok, thanks once again.
So under show_pci -v
I get PCI version 3.00
Vendor ID = 8086h, INTEL CORPORATION
Device ID = 2e30h
Device ID = 2e31h
Device ID = 27d8h
Device ID = 27d0h
Device ID = 27d2h
Device ID = 27c8h
Device ID = 27c9h
Device ID = 27cah
Device ID = 27cbh
Device ID = 27cch
Device ID = 244eh
Device ID = 27b8h
Device ID = 27dfh
Device ID = 27c0h
Device ID = 27dah
Vendor ID = 10deh
Device ID = 641h
Vendor ID = 10ech
Device ID = 8168h
Vendor ID = 10ech
Device ID = 8169h
IRQ routing = bus = 0 motherboard device =1
Vendor = 8086h, INTEL corporation
Device ID = 2e31h
IRQ routing = bus = 0 motherboard device =30
Vendor = 8086h,
Device ID = 244eh
IRQ routing = bus = 0 motherboard device =31
Device ID = 27b8h
Device ID = 27dfh
Device ID = 27c0h
Device ID = 27dah
IRQ routing = bus = 0 motherboard device =29
Device ID =  27c8h
Device ID = 27c9h
Device ID = 27cah
Device ID = 27cbh
Device ID = 27cch
IRQ routing = bus = 0 motherboard device =27
Device ID =  27d8h
IRQ routing = bus = 0 motherboard device =28
Device ID = 27d0h
Device ID = 27d2h
IRQ routing = bus = 0 slot = 32 device = 0
No card configured in slot
IRQ routing = bus = 4 slot = 1 device = 2
Vendor = 10ech
Device ID =  8169h
IRQ routing = bus = 4 slot = 2 device = 1
IRQ routing = bus = 3 motherboard device = 0
Vendor = 10ech
did 8168h
You have the Realtek 8169 Ethernet controllers, so you will have to run the
Net.rtl8169 driver. You have 2 devices, so you will have to start the driver
as follows:
Net.rtl8169 -V10ec -d8168 &
Net.rtl8169 -V10ec -d8169 -l2 &
Please note the capital 'V' and lower case 'd'.
> Device ID = 2e30h
> Device ID = 2e31h
> Device ID = 27d8h
> Device ID = 27d0h
> Device ID = 27d2h
> Device ID = 27c8h
> Device ID = 27c9h
> Device ID = 27cah
> Device ID = 27cbh
> Device ID = 27cch
> Device ID = 244eh
> Device ID = 27b8h
> Device ID = 27dfh
> Device ID = 27c0h
> Device ID = 27dah
> Vendor ID = 10deh
> Device ID = 641h
> Vendor ID = 10ech
> Device ID = 8168h
> Vendor ID = 10ech
> Device ID = 8169h
> Device ID = 2e31h
> Vendor = 8086h,
> Device ID = 244eh
> Device ID = 27b8h
> Device ID = 27dfh
> Device ID = 27c0h
> Device ID = 27dah
> Device ID =  27c8h
> Device ID = 27c9h
> Device ID = 27cah
> Device ID = 27cbh
> Device ID = 27cch
> Device ID =  27d8h
> Device ID = 27d0h
> Device ID = 27d2h
> Vendor = 10ech
> Device ID =  8169h
> Vendor = 10ech
> did 8168h
> http://community.qnx.com/sf/go/post54604
K2M 1W8
So I tried to run Net.rtl8169 -V10ec -d8168 & and I got:
"Net.rtl18169 INITIALIZATION ERROR 4"
However, when I did Net.rtl8169 -V10ec -d8169 -l2 & , I got
%1 - 20904 Done (1)  Net.rt18169 -V10ec -d8168
%2 + 21286 Running Net.rt18169 -V10ec -d8169 -12
When I tried to ping my outside external, I still get a hang.
You have to start Net first, then the network drivers and then TCP/IP.
Net &
Socket nodename &
Once you have done this, you can run ifconfig or dhcp.client.
> http://community.qnx.com/sf/go/post54609
K2M 1W8
Do I need to start up nettrap query first as well?  as
nettrap query
Net &
etc etc?
Because using Net & to start up the network gives me this message
27598 Done (255)  Net NG NET: Parse_Args() failed.
I'll continue to see what I come up with though.
Thanks to your help, I know I am getting close so thank you very much as well.
No, don't run nettrap at all. If you run 'sin' and Net is already running,
then don't start it again. The same applies to the drivers.
> nettrap query
> Net &
> etc etc?
> http://community.qnx.com/sf/go/post54613
K2M 1W8
Mr Brown,
  Thanks for your help.  I will work on this a little more but if you are around tomorrow, I will let you know how
things turn out in the morning.
Sorry Mr. Brown,
  Silly question but I will ask anyway... I set my socket to be 30... so when I set up tcp/ip do I need to say socket30
I'm not sure what you mean by "I set my socket to be 30."
On 10-05-13 3:50 PM, "Julian Babel" <community-noreply@qnx.com> wrote:
> Sorry Mr. Brown,
> I set up tcp/ip do I need to say socket30 &?
> http://community.qnx.com/sf/go/post54618
K2M 1W8
Sorry,
  Poor technical skills when you are trying to multitask by speaking to other people...haha.
So I did the following...
Net &
Socket.30 &
I got several initialization errors but noticed that my socket was not found (Socket.30 was not found).  I'm starting to
 think that even though the drivers are set up, my port may not be on? or in other words, my socket isnt configured?
turned "on?"
What do you think?
No, you cannot start Socket like that. The shell will try to find Socket.30
and not Socket, unless you renamed the Socket program to Socket.30.
Otherwise, it your node is 30, then you must start 'Socket 30 &'.
On 10-05-13 4:01 PM, "Julian Babel" <community-noreply@qnx.com> wrote:
> Sorry,
> people...haha.
> Net &
> Socket.30 &
> (Socket.30 was not found).  I'm starting to think that even though the drivers
> configured? turned "on?"
> What do you think?
> http://community.qnx.com/sf/go/post54621
K2M 1W8
Good Morning Mr Brown,
   Thanks for all your help.
I have done the following with the corresponding messages
>>Net &
%1 + 31037 Done (255)   Net NG Net: Parse_args() Failed
%1 + 31120 Running      Net.rtl8169 -V10ec -d8168
#Net.rtl8169: Initialization error 4
Net.rtl8169 -V10ec -d8169 l2 &
%1 - 31120 Done (1)              Net.rtl8169 -V10ec -d8168
%2 + 31553 Running              Net.rtl8169 -V10ec -d8169 l2
Socket 30 &
Socket: Unable to attach name /qnx/socket
%1 + 32665 Done (1)                  Socket 30
%2 - 31553 Done (1)                   Net.rtl8169 -V10ec -d8169 l2
Any thoughts?
If you boot your machine and run 'sin', is Net already running? Also check
to see if there are any instances of Net.rtl8169 running. If so, then you
don't need to start Net. Look at your /etc/config/sysinit.node file and see
what it is doing.
>>> Net &
> Socket 30 &
> Any thoughts?
> http://community.qnx.com/sf/go/post54668
K2M 1W8
So it looks like Net is running and two Net.rt18169 are running...When looking in my sysinit file I have this
#Image: /boot/sys/boot -v
#Image: /boot/sys/Proc32 -l 30
#Image: /boot/sys/Slib32
#Image: /boot/sys/Slib16
#Image: /bin/Fsys -Hdisk160
#Image: /bin/Fsys.atapi fsys -Ndsk0 -n0=hd0. -n5=cd0.
#Image: /bin/mount -p /dev/hd0.0 /dev/hd0.0t77 /
#Image: /bin/sinit TERM=qnxm
#export NODE=30
export KBD=en_US_101.kbd
export ABLANG=en
export CON_KBD=USA
export TZ=est05edt04,M4.1.0/2,M10.5.0/2
/bin/rtc -l hw
Dev &
emu87 &
Pipe &
/bin/Dev.ser -N/dev/ser1 3f8,4 &
Dev.ansi -Q -n6 &
reopen /dev/con1
kbd $CON_KBD
prefix -A /dev/console=/dev/con1
Dev.par &
Dev.pty -n16 &
Iso9660fsys /cd0.0=/dev/cd0.0 &
# Define the default CD Rom
/bin/prefix -A /cd=//0/cd0.0
/bin/Net -d8 &
/bin/Net.rtl8169 -l1 -pe800 -i11 &
/bin/Net.rt18169 -l2 -pd800 -i11 &
netmap -f
nameloc &
chkfsys -P /
if test -f /etc/config/bin/tcpip.$NODE
then
. /etc/config/bin/tcpip.$NODE
fi
if test -f /etc/config/bin/ph.$NODE
then
. /etc/config/bin/ph.$NODE
else
tinit -t /dev/con1 &
tinit -T /dev/con[2-6] &
fi
I'm thinking I dont need those two instances of Net.rtl8169 in the code...I could comment the first one ...-l1 out...but
 should I maybe include the subnet masks and ip address in the code so that it is hardcoded in the sys file?
If you only need one network running, then comment one of them out. You can
edit the tcpip.$NODE file to start Socket.
> #export NODE=30
> export ABLANG=en
> export CON_KBD=USA
> /bin/rtc -l hw
> Dev &
> emu87 &
> Pipe &
> Dev.ansi -Q -n6 &
> reopen /dev/con1
> kbd $CON_KBD
> Dev.par &
> Dev.pty -n16 &
> /bin/Net -d8 &
> netmap -f
> nameloc &
> chkfsys -P /
> then
> fi
> then
> else
> fi
> could comment the first one ...-l1 out...but should I maybe include the subnet
> http://community.qnx.com/sf/go/post54681
K2M 1W8
I commented out the one line with:
/bin/Net.rtl8169 -l2 -pd800 -i11 &
Since I don't need to run the net, and I commented out the Net l2 line, and also looking at the sin I guess we've
determined that the drivers are in fact running but it's the socket that may be issue?  You said I can edit the tcpip.$
NODE lines? does that mean I should replace it with tcpip.30?
Look at the /etc/config/bin/tcpip.$NODE file, where $NODE is the node number
of your machine. Eg. tcpip.1. Edit this file to suite your requirements.
> also looking at the sin I guess we've determined that the drivers are in fact
> tcpip.$NODE lines? does that mean I should replace it with tcpip.30?
> http://community.qnx.com/sf/go/post54689
K2M 1W8
Ok, so looked within tcpip.30 and did some minor editing
#! /bin/ksh
/usr/ucb/Socklet -p 1 node$NODE &
/usr/ucb/ifconfig lo0 localhost up
/usr/ucb/ifconfig en1 node$NODE up
/usr/ucb/inetd /etc/config/inetd.30 &
I was thinking that should fix my problem, but alas, no luck.  I'm starting to run out of options.  I did deal with tcp
network issues with my other boxes, but I was able to edit the code within the sysinit file.  The difference between
those boxes and these is that I was using Digicards, whereas this will be my first ethernet box.  Why it doesn't seem to
 recognize the socket, I am a bit confused.
Is node30 defined in your /etc/hosts file? Is en1 the interface that is
running? Look at 'netstat -in' to see what interface is configured. You can
also look at the TCP/IP documentation to see how to setup an TCP/IP
connection.
> #! /bin/ksh
> run out of options.  I did deal with tcp network issues with my other boxes,
> between those boxes and these is that I was using Digicards, whereas this will
> be my first ethernet box.  Why it doesn't seem to recognize the socket, I am a
> bit confused.
> http://community.qnx.com/sf/go/post54712
K2M 1W8
node30 is defined in the host file
en1 is the interface used
netstat -in gives me the following:
Name:       Mtu     Network       address
en1          1500    <link>          0.26.f2.ac.bd.9
en1          1500    192.168.1   192.168.1.30
ppp0*       1500   <link>
lo0            1536   <link>
lo0            1536   127              127.0.0.1
I'll look for the tcp/ip documentation..I thought I tried that but i'll give it another shot.  Also..I know i've been
saying socket but I get pings from 192.1168.1.30 but say..I want it to my external driver which is .50...I can't reach
out.  I'll try the documentation as well though.
So I tried to go back into sysinit.30 and I did the following
I added this at the end of the current script
sleep4
nettrap
sleep4
#network
/etc/netstart
/usr/ucb/ifconfig en1 192.168.1.30 netmask 255.255.255.0
/usr/ucb/route add default 192.168.1.255
/usr/ucb/route/ add -net 192.168.1.30 192.168.1.255
sleep 2
I rebooted and unfortunately it hung..think I need to do some more tweaking?
Don't run nettrap!
> sleep4
> nettrap
> sleep4
> #network
> /etc/netstart
> sleep 2
> http://community.qnx.com/sf/go/post54732
K2M 1W8
It seems one of my biggest issues, even while following the TCP/IP configuration guide is that whenever I seem to type
anything initializing an editor e.g. Socket -d forward hostname, etc, I always seem to get unable to attach name.  I'm
very confused on how i'm not getting anything to respond.  BTW, I did take the nettrap out, but it only hung up my
original ip (the .30), so I just commented it out.  Interesting to note that when I do an nslookup, it does identify my
server as node30, but I get nothing for the addresses...
Any thoughts?
Maybe you should be using dhcp.client rather than ifconfig.
> configuration guide is that whenever I seem to type anything initializing an
> attach name.  I'm very confused on how i'm not getting anything to respond.
> BTW, I did take the nettrap out, but it only hung up my original ip (the .30),
> it does identify my server as node30, but I get nothing for the addresses...
> Any thoughts?
> http://community.qnx.com/sf/go/post54761
K2M 1W8
Have any links that can show me more about using dhcp.client?  I have to admit, my knowledge in that is lacking.
No, you just run dhcp.client and if you have a dhcp server on your network,
it will give you an IP address.
> http://community.qnx.com/sf/go/post54764
K2M 1W8
hrmm..well I just tried that and it doesn't seem like the IP address is the issue.  I typed sin and realized that Socket
 is also listed as being initialized.  You don't think this isn't an issue that I have closed sockets? I looked within
tcpip and sysinit and both look fine.  I'm just curious...the new version, 2009 (which i do have installed) included all
 the latest and greatest from the tcp/ip configuration?
There is a TCPIP 5.0 update on our web, but I don't know whether this will
solve your problem, as I don't know what you are trying to achieve.
> issue.  I typed sin and realized that Socket is also listed as being
> I looked within tcpip and sysinit and both look fine.  I'm just curious...the
> new version, 2009 (which i do have installed) included all the latest and
> http://community.qnx.com/sf/go/post54768
K2M 1W8
Good Morning Mr. Brown,
  I apologize if my objective seemed unclear.  Basically, i've configured several qnx systems for my workplace using QNX
 4.  I've always had an issue with establishing the networks on them in recent months due to the failing disk drives
that enable the tcp/ip configuration.  I managed to override this by using digi card drivers and previous configuration
setups on pre-existing machines.  Currently, the new box that I have been instructed to set up MUST have ethernet
capabilities.  We are getting rid of Digi.  I have no disk drive, but luckily QNX released their 2009 cd patch that
cleared the majority of my previous hardware woes.  The only exception seems to be this networking issue.
In the initialization of my setup, I enabled a TCP/IP connection and set the node to 30, enabling my network, I assume,
to be 192.168.1.30.  When I ping this, I get a successful ping.  However, I wanted to test this on an outside network,
so I attached a network enabled WD external harddrive, plugging in the ethernet cable, tried to ping (eg 192.168.1.50)
and am unable to get a pulse.  This is where my confusion seems to manifest.
Your advice on loading the drivers was excellent, however, under your guidance, you were right in assuming that the
drivers seem to already be active and functioning, which is why I keep getting the "error" messages (plus when you
instructed to use 'sin', I saw this as well).
So right now, my problem seems to be getting that outside connection to work.  I'm currently looking at old files from
previous qnx machines that were digi enabled to see what the missing link was.  I'm not too sure what else I may be able
 to do though.
I appreciate that time you've taken so far to help me with this. Does this clarify things a bit?
If you ping 192.168.1.30, you are pinging yourself, so this will work. How
are you connecting to the external hard disk? Is it via a switch or a direct
cable? If it is a direct cable, it it a crossover cable? Can you connect to
your internal network and ping other machines?
> several qnx systems for my workplace using QNX 4.  I've always had an issue
> disk drives that enable the tcp/ip configuration.  I managed to override this
> by using digi card drivers and previous configuration setups on pre-existing
> have ethernet capabilities.  We are getting rid of Digi.  I have no disk
> drive, but luckily QNX released their 2009 cd patch that cleared the majority
> issue.
> node to 30, enabling my network, I assume, to be 192.168.1.30.  When I ping
> network, so I attached a network enabled WD external harddrive, plugging in
> the ethernet cable, tried to ping (eg 192.168.1.50) and am unable to get a
> guidance, you were right in assuming that the drivers seem to already be
> when you instructed to use 'sin', I saw this as well).
> I'm currently looking at old files from previous qnx machines that were digi
> able to do though.
> http://community.qnx.com/sf/go/post54834
K2M 1W8
It's just a direct cable and yes, it's a crossover cable.  No, I don't believe I can ping other machines.  I was hoping
that the direct connect would be a good test to see if I could connect to internal machines.  I believe their might be
two ethernet cards in my machine.  Eventhough I went into the sysinit file and commented the one driver out, you think
this may be causing an interrupt?
Are you sure that you are connecting to the active interface? Run 'netinfo
-L1' and see if you have a link and whether packets are being transmitted
and/or received. If not, try the other interface. Run 'netstat -in' to see
which interface has the IP address (en1 or en2).
> I can ping other machines.  I was hoping that the direct connect would be a
> might be two ethernet cards in my machine.  Eventhough I went into the sysinit
> file and commented the one driver out, you think this may be causing an
> interrupt?
> http://community.qnx.com/sf/go/post54848
K2M 1W8
Oh. Interesting.  It looks like I am not connected.  No packets are being transmitted/received.  And en1 has that
interface.
If you look at the output from 'netinfo -L1', does the Media Rate line show
a speed? If not, then that is why you cannot communicate. Try connecting via
a switch.
> transmitted/received.  And en1 has that interface.
> http://community.qnx.com/sf/go/post54851
K2M 1W8
It shows 1000Mb/s HDX.
1000Mb/s HDX is an invalid duplex for gigabit. Gigabit should only work at
1000Mb/s FDX. I suggest you try a switch.
> http://community.qnx.com/sf/go/post54856
K2M 1W8
Ok, so I tried just setting up a local hub.  Used a switch to connect to the qnx box and have a connection from the
harddrive to the switch and reset.  Still not getting anything.
Does the hard disk work on another machine with the same IP address?
> qnx box and have a connection from the harddrive to the switch and reset.
> http://community.qnx.com/sf/go/post54858
K2M 1W8
Yes.  I am going to try to pull out one of the drivers. I'm curious if it is partly a hardware issue.
Good Grief,
  I figured out the problem.  I hardcoded a minor change within the sysinit file.  However, the main problem as
embarrasing to admit, was that the IP address was being read from the ethernet port in the pci slot and not the
motherboard as I had the cable plugged into the entire time.  As much as I was switching cables about, I neglected the
one from the driver..so quick switch...worked.
Well..back to EE 101.  Thanks for all your help and patience Mr. Brown.
Good news!
Hugh.
On 10-05-17 1:18 PM, "Julian Babel" <community-noreply@qnx.com> wrote:
> Good Grief,
> file.  However, the main problem as embarrasing to admit, was that the IP
> switching cables about, I neglected the one from the driver..so quick
> switch...worked.
> http://community.qnx.com/sf/go/post54881
K2M 1W8
