Forum Topic - ClockPeriod questions about arguments:
How small could I make the clock period and what consequences can arise from setting a smaller that 1ms clock? And if i
set  a clock of 500 microseconds does that make the jitter smaller, for a gpio toggle of 1 milisecond done with timers.
George Vintila
RE: ClockPeriod questions about arguments
> From: gheroghe vintila [mailto:community-noreply@qnx.com]
> Sent: March 27, 2010 9:12 AM
> To: qnx4-community
> Subject: ClockPeriod questions about arguments
Increase CPU usage.
> And if i set  a clock of 500
Depends what causes the jitter and how your program is designed.
> Thanks,
> George Vintila
> QNX4 Community Support
> http://community.qnx.com/sf/go/post50619
Re: RE: ClockPeriod questions about arguments
First off all thanks for help, and secondly i want to give more information about the program:
The program settings are explained in my other post :    http://community.qnx.com/sf/discussion/do/listPosts/projects.
community/discussion.qnx4_community_support.topc12867
What are the possible causes of the jitter after applying the settings described in the other post? I must be missing
something because i cant believe that the jitter is normal.
Does it reduce the jitter if i set the timer period to the period of the signal that i want to put on the GPIO PIN?
