Re: QNX4 driver PENMOUNT touchscreen
05/20/2010 8:53 AM
post55230
For the future if you do not have the input ddk (not really an official package just something I put together that
allows you to build the stuff) you can create your own driver using a resource manager and then convert the data packets
into the 'generic' protocol that the Input driver supports:
Generic interface for non serial/ps2 touchscreens
This is the generic protocol that is expected. The external driver
must use the following protocol in order for the generic driver to
function correctly. The number of bits is not critical. This can
be changed via the command line option -B to specify the number of
bits for each coordinate. The default is 14. If you do not use
all 14, make certain that the values not used are 0.
MSB Bits LSB
Data Sequence 7 6 5 4 3 2 1 0
S-Byte 1 1 S6 XXXXXXXXX Reserved XXXXXXXX
X-Byte 2 0 X6 X5 X4 X3 X2 X1 X0
x-Byte 3 0 X13 X12 X11 X10 X9 X8 X7
Y-Byte 4 0 Y6 Y5 Y4 Y3 Y2 Y1 Y0
y-Byte 5 0 Y13 Y12 Y11 Y10 Y9 Y8 Y7
S0-S5 Reserved
S6 Proximity 1 = Touchscreen is being touched (a
touchdown or a continued touch).
0 = Touchscreen is not being touched (a
touch liftoff or inactive).
S7 Packet Always 1.
synchronization
Then start the Input driver using the generic module and point it to your resmgr mount point and then it will handle the
rest.
Best regards,
Erick
