Paul Lemieux
02/18/2010 11:33 AM
post47680
I'm installing QNX4 on a machine with no floppy drive. I entered the license number
manually when prompted to do so. The problem now is : how do I run the license
utility?
On a machine with a floppy I would run:
license /etc/licenses /fd0 (this copies licenses to a floppy)
then, to copy licenses from floppy to machine:
license /fd0
any help would be greatly appreciated.
Paul L.
Hugh Brown
02/18/2010 11:35 AM
post47681
You can edit the /.licenses file and add licenses manually.
> number
> utility?
> license /fd0
> Paul L.
> QNX4 Community Support
> http://community.qnx.com/sf/go/post47680
Paul Lemieux
02/23/2010 8:42 AM
post47973
<FONT face="Default Sans Serif,Verdana,Arial,Helvetica,sans-serif" size=2><DIV>Thanks for the quick reply. The problem
is that /etc/licenses is a directory and is asking me for a filename when I exit vedit. Not sure how to get</DIV><DIV>
around this. Can you help me out?</DIV><DIV>thanks & regards,</DIV><DIV><BR> </DIV><DIV>Paul Lemieux<BR>Control Systems
Technologist<BR>AbitibiBowater<BR>Iroquois Falls Division<BR>1 Park Street<BR>Iroquois Falls, ON, Canada P0K 1E0<BR>
(705)-258-3931 ext.4026<BR><DIV><BR></DIV><FONT color=#990099>-----Hugh Brown <community-noreply@qnx.com> wrote: -----<
BR><BR></FONT><BLOCKQUOTE style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid
; MARGIN-RIGHT: 0px">To: qnx4-community <post47681@community.qnx.com><BR>From: Hugh Brown <community-noreply@qnx.com><BR
>Date: 02/18/2010 11:35AM<BR>Subject: Re: licensing<BR><BR><FONT face="Default Monospace,Courier New,Courier,monospace"
size=2>You can edit the /.licenses file and add licenses manually.<BR><BR><BR><BR>On 10-02-18 11:33 AM, "Paul Lemieux" <
community-noreply@qnx.com> wrote:<BR><BR>> I'm installing QNX4 on a machine with no floppy drive. I entered the license<
BR>> number<BR>> manually when prompted to do so. The problem now is : how do I run the license<BR>> utility?<BR>> On a
machine with a floppy I would run:<BR>> license /etc/licenses /fd0 (this copies licenses to a floppy)<BR>> then, to
copy licenses from floppy to machine:<BR>> license /fd0<BR>> <BR>> any help would be greatly appreciated.<BR>> Paul L.<
BR>> <BR>> <BR>> <BR>> _______________________________________________<BR>> <BR>> QNX4 Community Support<BR>> <A href="
http://community.qnx.com/sf/go/post47680" target=blank>http://community.qnx.com/sf/go/post47680</A><BR>> <BR><BR><BR>
<BR><BR>_______________________________________________<BR><BR>QNX4 Community Support<BR><A href="http://community.qnx.
com/sf/go/post47681" target=blank>http://community.qnx.com/sf/go/post47681</A><BR><BR></FONT></BLOCKQUOTE><BR></DIV></
FONT>
Jacek Rudnicki
02/25/2010 5:39 AM
post48255
Hi Paul,
Is there a USB port available ?
If yes, then you can use Pendrive with QNX4 filesystem to transfer old-style licenses (# license source destination).
Jacek
Paul Lemieux
02/25/2010 8:16 AM
post48272
<FONT face="Default Sans Serif,Verdana,Arial,Helvetica,sans-serif" size=2><DIV>Thanks for the reply. Yes there is a USB
port available. Sorry but I don't know what you mean by Pendrive.</DIV><DIV>regards,</DIV><DIV>Paul</DIV><DIV><BR> </DIV
><DIV>Paul Lemieux<BR>Control Systems Technologist<BR>AbitibiBowater<BR>Iroquois Falls Division<BR>1 Park Street<BR>
Iroquois Falls, ON, Canada P0K 1E0<BR>(705)-258-3931 ext.4026<BR><DIV><BR></DIV><FONT color=#990099>-----Jacek Rudnicki
<community-noreply@qnx.com> wrote: -----<BR><BR></FONT><BLOCKQUOTE style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-
LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">To: qnx4-community <post48255@community.qnx.com><BR>From:
Jacek Rudnicki <community-noreply@qnx.com><BR>Date: 02/25/2010 05:39AM<BR>Subject: Re: licensing<BR><BR><FONT face="
Default Monospace,Courier New,Courier,monospace" size=2>Hi Paul,<BR><BR>Is there a USB port available ?<BR><BR>If yes,
then you can use Pendrive with QNX4 filesystem to transfer old-style licenses (# license source destination).<BR><BR>
Regards,<BR>Jacek <BR><BR><BR><BR><BR><BR><BR>_______________________________________________<BR><BR>QNX4 Community
Support<BR><A href="http://community.qnx.com/sf/go/post48255" target=blank>http://community.qnx.com/sf/go/post48255</A><
BR><BR></FONT></BLOCKQUOTE><BR></DIV></FONT>
Jacek Rudnicki
02/25/2010 9:07 AM
post48282
Pendrive is a USB Stick.
You can also use USB HDD or even External USB Floppy Drive, everything what is supported by the Fsys.umass driver.
Jacek
Alex Burk(deleted)
02/27/2010 6:00 PM
post48474
Paul !
1.When you entered the license number correctly
and pushed button "Add/F5" - QNX4 automatically adds your license into file
/.licenses on installing partition and runs utility license
2.After that you can push "Continue" -> "Done" and "Start/F2" for installing
> number
> utility?
> license /fd0
> Paul L.
Paul Lemieux
03/03/2010 1:17 PM
post48741
<FONT face="Default Sans Serif,Verdana,Arial,Helvetica,sans-serif" size=2><DIV>Thank you for your reply, here is my
issue: </DIV><DIV> </DIV><DIV>I'm installing qnx4 & qnx windows on a machine with no floppy drive. It is going to be
node 11 on an existing qnx4 network. When I install qnx4 from the installation cd it prompts me for the license numbers.
If I type in the license numbers such as qnx0063806n001 or winrt0132570n001 which are the old type of license found in
/etc/licenses, it will not allow me</DIV><DIV>to "Add/F5". If I put in the license number from another machine, such as
qnx.00511520-xxxx which is the new type of license, it allows me to "Add/F5" but this is a 1 node </DIV><DIV>license key
. Any help you can give me with this would be greatly appreciated. <BR></DIV><DIV>Paul Lemieux <BR>Control Systems
Technologist <BR>AbitibiBowater <BR>Iroquois Falls Division <BR>1 Park Street <BR>Iroquois Falls, ON, Canada P0K 1E0 <BR
>(705)-258-3931 ext.4026 <BR><DIV><BR></DIV><FONT color=#990099>-----Alex Burk <community-noreply@qnx.com> wrote: -----
<BR><BR></FONT><BLOCKQUOTE style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px
solid; MARGIN-RIGHT: 0px">To: qnx4-community <post48474@community.qnx.com> <BR>From: Alex Burk <community-noreply@qnx.
com> <BR>Date: 02/27/2010 06:00PM <BR>Subject: Re: licensing <BR><BR><FONT face="Default Monospace,Courier New,Courier,
monospace" size=2>Paul ! <BR><BR>1.When you entered the license number correctly <BR> and pushed button "Add/F5" -
QNX4 automatically adds your license into file <BR> /.licenses on installing partition and runs utility license <BR>
2.After that you can push "Continue" -> "Done" and "Start/F2" for installing <BR><BR><BR>> I'm installing QNX4 on a
machine with no floppy drive. I entered the license <BR>> number <BR>> manually when prompted to do so. The problem now
is : how do I run the license <BR>> <BR>> utility? <BR>> On a machine with a floppy I would run: <BR>> license /etc/
licenses /fd0 (this copies licenses to a floppy) <BR>> then, to copy licenses from floppy to machine: <BR>> license /
fd0 <BR>> <BR>> any help would be greatly appreciated. <BR>> Paul L. <BR><BR><BR><BR><BR><BR><BR>
_______________________________________________ <BR><BR>QNX4 Community Support <BR><A href="http://community.qnx.com/sf/
go/post48474" target=blank>http://community.qnx.com/sf/go/post48474 </A><BR></FONT></BLOCKQUOTE><BR><BR>[attachment "
qnx4.jpg" removed by Paul Lemieux/IF/CSC] <BR></DIV></FONT>
Jacek Rudnicki
03/04/2010 8:43 AM
post48775
Hi Paul,
>It is going to be node 11 on an existing qnx4 network.
>which are the old type of license found in /etc/licenses, it will not allow me to "Add/F5".
The only new-style licenses can be typed during installation.
A old-style licenses must be transfered via "license" command.
You can tranfer them directly onto floppy drive or to specific path/directory which can be located on different media
like USB Stick, USB HDD, etc. ...
>me to "Add/F5" but this is a 1 node license key.
To solve your problem I suggest to use the latest QNX4 Installation CD (November 2009).
Here are some necessary steps:
1) install QNX4 O/S only (use new-style license just to pass installation process completely),
2) meantime on the another machine transfer licenses onto floppy drive or USB Stick,...
Floppy method:
# license /etc/licenses/* /dev/fd0
USB Stick method is more complicated. The USB stack "io-usb" manager and "Fsys.umass" driver will be necessary. In short
you will need to create QNX4 partition, initialize filesystem on USB Stick and mount it. Finally transfer licenses to
mount directory (i.e. usb_stick):
# license /etc/licenses/* /usb_stick
3) after installation boot from HDD drive,
4) start io-usb and Fsys.umass driver,
4a) Floppy method
external USB floppy drive should be detected as /dev/fd0, so type
# license
or
# license /dev/fd0
4b) USB Stick method
mount your device (i.e. as /usb_stick) and type
# license /usb_stick/* /etc/licenses
5) refresh licenses
# license -r
check if a new licenses was added
# licinfo -a
6) now having license for qnx windows install this package from CD
# /cd/bin/phinstall
After everything don't forget to remove the /.license file with "temporary" license key.
Good luck,
Jacek
Paul Lemieux
03/04/2010 2:11 PM
post48836
<FONT face="Default Sans Serif,Verdana,Arial,Helvetica,sans-serif" size=2><DIV>Thank you very much for your reply. I am
trying the usb floppy option. I have the December 2009 version of qnx4 as well as the latest usb driver but I can only
get the usb stick to operate as a dos device & no luck with floppy. Do you have any experience with these usb drivers?</
DIV><DIV>thanks,<BR></DIV><DIV>Paul Lemieux<BR>Control Systems Technologist<BR>AbitibiBowater<BR>Iroquois Falls Division
<BR>1 Park Street<BR>Iroquois Falls, ON, Canada P0K 1E0<BR>(705)-258-3931 ext.4026<BR><DIV><BR></DIV><FONT color=#990099
>-----Jacek Rudnicki <community-noreply@qnx.com> wrote: -----<BR><BR></FONT><BLOCKQUOTE style="PADDING-RIGHT: 0px;
PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">To: qnx4-community <post48775@
community.qnx.com><BR>From: Jacek Rudnicki <community-noreply@qnx.com><BR>Date: 03/04/2010 08:43AM<BR>Subject: Re:
licensing<BR><BR><FONT face="Default Monospace,Courier New,Courier,monospace" size=2>Hi Paul,<BR><BR>>I'm installing
qnx4 & qnx windows on a machine with no floppy drive.<BR>>It is going to be node 11 on an existing qnx4 network.<BR>>
When I install qnx4 from the installation cd it prompts me for the license numbers.<BR><BR>>If I type in the license
numbers such as qnx0063806n001 or winrt0132570n001<BR>>which are the old type of license found in /etc/licenses, it will
not allow me to "Add/F5".<BR><BR>The only new-style licenses can be typed during installation.<BR>A old-style licenses
must be transfered via "license" command. <BR>You can tranfer them directly onto floppy drive or to specific path/
directory which can be located on different media like USB Stick, USB HDD, etc. ...<BR><BR>>If I put in the license
number from another machine, such as <BR>>qnx.00511520-xxxx which is the new type of license, it allows<BR> >me to "Add/
F5" but this is a 1 node license key.<BR><BR>To solve your problem I suggest to use the latest QNX4 Installation CD
(November 2009).<BR><BR>Here are some necessary steps: <BR>1) install QNX4 O/S only (use new-style license just to pass
installation process completely),<BR><BR>2) meantime on the another machine transfer licenses onto floppy drive or USB
Stick,... <BR><BR>Floppy method:<BR># license /etc/licenses/* /dev/fd0<BR><BR>USB Stick method is more complicated. The
USB stack "io-usb" manager and "Fsys.umass" driver will be necessary. In short you will need to create QNX4 partition,
initialize filesystem on USB Stick and mount it. Finally transfer licenses to mount directory (i.e. usb_stick):<BR>#
license /etc/licenses/* /usb_stick<BR><BR>3) after installation boot from HDD drive,<BR><BR>4) start io-usb and Fsys.
umass driver,<BR><BR>4a) Floppy method <BR> external USB floppy drive should be detected as /dev/fd0, so type<BR>
# license<BR> or<BR> # license /dev/fd0<BR><BR>4b) USB Stick method<BR> mount your device (i.e. as /
usb_stick) and type<BR> # license /usb_stick/* /etc/licenses<BR><BR>5) refresh licenses<BR># license -r<BR> <BR>
check if a new licenses was added<BR># licinfo -a<BR><BR>6) now having license for qnx windows install this package from
CD<BR># /cd/bin/phinstall<BR><BR>After everything don't forget to remove the /.license file with "temporary" license...
Jacek Rudnicki
03/05/2010 3:29 AM
post48876
Paul,
It is difficult to read all your posts.
Can you do something with that ?
>I am trying the usb floppy option. I have the December 2009 version of qnx4 as
>well as the latest usb driver but I can only get the usb stick to operate as a dos
As far as I know the "license" command works for the QNX4 filesystem only.
You can switch from dos to qnx4 device (use "fdisk" and "dinit" against usb stick).
USB floppy drive should be detected automatically but the Fsys.umass.
First start USB Stack (# io-usb &) and connect USB floppy drive.
The "usb" command should print more info about this device (# usb -vvv).
Then start (# Fsys.umass &).
Does this driver print anything on the screen ?
Paul Lemieux
03/05/2010 8:15 AM
post48883
<FONT face="Default Sans Serif,Verdana,Arial,Helvetica,sans-serif" size=2><DIV>Thanks again for the reply. This is the
first time dealing with usb devices on qnx4. We have a large amount of qnx4 machines in this plant & we are trying to
keep them</DIV><DIV>running with new hardware. When I run the "usb" command I get a lot of info about the usb floppy.
When I run (Fsys.umass) I get the following:</DIV><DIV> </DIV><DIV>target=0 lun=0 Direct-Access(0)-TEAC FD-05PUB rev:
1043</DIV><DIV> </DIV><DIV>How do I now get this to run as a qnx device?</DIV><DIV> </DIV><DIV>thanks,</DIV><DIV><BR> </
DIV><DIV>Paul Lemieux<BR>Control Systems Technologist<BR>AbitibiBowater<BR>Iroquois Falls Division<BR>1 Park Street<BR>
LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">To: qnx4-community <post48876@community.qnx.com><BR>From:
Jacek Rudnicki <community-noreply@qnx.com><BR>Date: 03/05/2010 03:29AM<BR>Subject: Re: licensing<BR><BR><FONT face="
Default Monospace,Courier New,Courier,monospace" size=2>Paul,<BR><BR>It is difficult to read all your posts. <BR>Can you
do something with that ?<BR><BR>>I am trying the usb floppy option. I have the December 2009 version of qnx4 as<BR>>
well as the latest usb driver but I can only get the usb stick to operate as a dos<BR>>device & no luck with floppy. Do
you have any experience with these usb drivers?<BR><BR>As far as I know the "license" command works for the QNX4
filesystem only.<BR>You can switch from dos to qnx4 device (use "fdisk" and "dinit" against usb stick).<BR><BR><BR>USB
floppy drive should be detected automatically but the Fsys.umass.<BR><BR>First start USB Stack (# io-usb &) and connect
USB floppy drive.<BR>The "usb" command should print more info about this device (# usb -vvv).<BR>Then start (# Fsys.
umass &).<BR>Does this driver print anything on the screen ?<BR><BR><BR><BR><BR>
_______________________________________________<BR><BR>QNX4 Community Support<BR><A href="http://community.qnx.com/sf/go
/post48876" target=blank>http://community.qnx.com/sf/go/post48876</A><BR><BR></FONT></BLOCKQUOTE><BR></DIV></FONT>
Hugh Brown
03/05/2010 8:17 AM
post48884
This is what your posting looks like. Very difficult to read.
> size=2><DIV>Thanks again for the reply. This is the first time dealing with
> & we are trying to keep them</DIV><DIV>running with new hardware. When I
> run the "usb" command I get a lot of info about the usb floppy. When I run
> rev:1043</DIV><DIV> </DIV><DIV>How do I now get this to run as a qnx
> device?</DIV><DIV> </DIV><DIV>thanks,</DIV><DIV><BR> </DIV><DIV>Paul
> qnx4-community <post48876@community.qnx.com><BR>From: Jacek Rudnicki
> size=2>Paul,<BR><BR>It is difficult to read all your posts. <BR>Can you do
> December 2009 version of qnx4 as<BR>>well as the latest usb driver but I
> with floppy. Do you have any experience with these usb drivers?<BR><BR>As far
> as I know the "license" command works for the QNX4 filesystem only.<BR>You can
> stick).<BR><BR><BR>USB floppy drive should be detected automatically but the
> Fsys.umass.<BR><BR>First start USB Stack (# io-usb &) and connect USB
> usb -vvv).<BR>Then start (# Fsys.umass &).<BR>Does this driver print
> ?<BR><BR><BR><BR><BR>_______________________________________________<BR><BR>QN
> X4 Community Support<BR><A href="http://community.qnx.com/sf/go/post48876"
> http://community.qnx.com/sf/go/post48883
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
Jacek Rudnicki
03/05/2010 8:38 AM
post48888
>target=0 lun=0 Direct-Access(0)-TEAC FD-05PUB rev:1043
Looks like usb floppy drive was detected. The /dev/fd0 device should be created and available in system.
Now type:
# license
or
# license /dev/fd0
or
# license /dev/fdX
Of course if licenses were transfered before
(on the older machine with standard floppy).
Paul Lemieux
03/05/2010 1:39 PM
post48923
<FONT face="Default Sans Serif,Verdana,Arial,Helvetica,sans-serif" size=2><DIV>thanks for the quick reply. After I run
Fsys.umass do I need to run the mount command. If I run mount/dev/fd0 /fd0 I get an error. I'm just about to give up
on this machine.</DIV><DIV>thanks,<BR></DIV><DIV>Paul Lemieux<BR>Control Systems Technologist<BR>AbitibiBowater<BR>
Iroquois Falls Division<BR>1 Park Street<BR>Iroquois Falls, ON, Canada P0K 1E0<BR>(705)-258-3931 ext.4026<BR><DIV><BR></
DIV><FONT color=#990099>-----Jacek Rudnicki <community-noreply@qnx.com> wrote: -----<BR><BR></FONT><BLOCKQUOTE style="
PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">To: qnx4-
community <post48888@community.qnx.com><BR>From: Jacek Rudnicki <community-noreply@qnx.com><BR>Date: 03/05/2010 08:38AM<
BR>Subject: Re: licensing<BR><BR><FONT face="Default Monospace,Courier New,Courier,monospace" size=2>>When I run (Fsys.
umass) I get the following:<BR>>target=0 lun=0 Direct-Access(0)-TEAC FD-05PUB rev:1043<BR>>How do I now get this to
run as a qnx device?<BR><BR>Looks like usb floppy drive was detected. The /dev/fd0 device should be created and
available in system.<BR><BR>Now type:<BR># license <BR>or<BR># license /dev/fd0<BR>or<BR># license /dev/fdX<BR><BR>Of
course if licenses were transfered before<BR># license /etc/licenses/* /dev/fd0<BR>(on the older machine with standard
floppy).<BR><BR><BR><BR><BR><BR>_______________________________________________<BR><BR>QNX4 Community Support<BR><A href
="http://community.qnx.com/sf/go/post48888" target=blank>http://community.qnx.com/sf/go/post48888</A><BR><BR></FONT></
Jacek Rudnicki
03/08/2010 3:43 AM
post48977
>After I run Fsys.umass do I need to run the mount command.
It depends and there are two options.
1) QNX License diskette.
Such floppy disk is "special" and can't be mounted.
Also you can use it later during installation on machine with standard floppy drive.
To create type:
# license /etc/license/* /dev/fd0
To use it type:
# license
or
# license /dev/fd0
2) QNX 4 diskette.
It must be initialized first:
# dinit /dev/fd0
then you can mount it:
# mount /dev/fd0 /fd0
and transfer licenses:
# license /etc/licenses/* /fd0
To use it:
# license /fd0/* /etc/licenses
>If I run mount /dev/fd0 /fd0 I get an error.
Probably this is DOS or QNX License diskette.
Before mounting initialize QNX4 File System on it:
# dinit /dev/fd0
Jacek
Paul Lemieux
03/09/2010 7:52 AM
post49074
<FONT face="Default Sans Serif,Verdana,Arial,Helvetica,sans-serif" size=2><DIV>Thank you for all your help.....I finally
got this working!</DIV><DIV>regards,</DIV><DIV><BR> </DIV><DIV>Paul Lemieux<BR>Control Systems Technologist<BR>
AbitibiBowater<BR>Iroquois Falls Division<BR>1 Park Street<BR>Iroquois Falls, ON, Canada P0K 1E0<BR>(705)-258-3931 ext.
4026<BR><DIV><BR></DIV><FONT color=#990099>-----Jacek Rudnicki <community-noreply@qnx.com> wrote: -----<BR><BR></FONT><
BLOCKQUOTE style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT:
0px">To: qnx4-community <post48977@community.qnx.com><BR>From: Jacek Rudnicki <community-noreply@qnx.com><BR>Date: 03/
08/2010 03:43AM<BR>Subject: Re: licensing<BR><BR><FONT face="Default Monospace,Courier New,Courier,monospace" size=2>>
After I run Fsys.umass do I need to run the mount command.<BR>It depends and there are two options.<BR><BR>1) QNX
License diskette. <BR>Such floppy disk is "special" and can't be mounted.<BR>Also you can use it later during
installation on machine with standard floppy drive.<BR><BR>To create type:<BR># license /etc/license/* /dev/fd0<BR><BR>
To use it type:<BR># license <BR>or <BR># license /dev/fd0<BR><BR>2) QNX 4 diskette.<BR>It must be initialized first:<
BR># dinit /dev/fd0<BR><BR>then you can mount it:<BR># mount /dev/fd0 /fd0<BR><BR>and transfer licenses:<BR># license /
etc/licenses/* /fd0<BR><BR>To use it:<BR># mount /dev/fd0 /fd0<BR># license /fd0/* /etc/licenses<BR><BR><BR>>If I run
mount /dev/fd0 /fd0 I get an error. <BR>Probably this is DOS or QNX License diskette.<BR>Before mounting initialize
QNX4 File System on it:<BR># dinit /dev/fd0<BR><BR>Regards,<BR>Jacek<BR><BR><BR><BR>
/post48977" target=blank>http://community.qnx.com/sf/go/post48977</A><BR><BR></FONT></BLOCKQUOTE><BR></DIV></FONT>
Alex Burk(deleted)
03/11/2010 4:08 AM
post49247
How to install old_style licenses on PC without usb, floppy (even a floppy controller).
1. Creating lic.img file with old_style licenses (small virtual hard disk)
- contig lic.img 1440000
- mountimg –t78 lic.img
- dinit –h /dev/hd0.0t78
- mount /dev/hd0.0t78 /lic
- mkdir /lic/licenses
- license /etc/licenses /lic/licenses
2. Adding file lic.img to QNX4_INSTALL.iso (by UltraISO utility or other) to main directory.
YOU HAVE INSTALLATION DISK WITH OLD_STYLE LICENSES !
3. Run installation on new PC
4. When will window “Add_Licenses” – run shell by “QNX” button (left bottom corner).
5. Moving licenses to new partition :
- cp /cd/lic.img /
- mountimg –t78 /lic.img
- license /lic/licenses /etc/licenses
- license -r
6. Close shell and push buttons “From floppy / F4” -> “Continue” -> “Done”
7. That’s all ! We can run “Start/F2” !
Good luck
AlexBurk
p.s.
1. utility contig can be used to create a contiguous QNX4 Fsys-hosted disk file ...
for work with mountimg utility.See attachment.
For src see :
http://www.openqnx.com/PNphpBB2+viewtopic-t-6642-highlight-mountimg.html
2. If PC hasn’t floppy controller – don’t push “From floppy / F4”,
after command “license –r “ restart installation AS UPGRADE !.
3.You can create batch file for point 5 and add it to installation disk :)
