Forum Topic - Intel LAN drivers:
Intel LAN drivers
Dear all,
I have two motherboards with Intel LAN cards, models 82562GZ and 82551ER. I tried both but don’t work under QNX.
With the 82562GZ I load the Net.ether82557 and the 701 patch. It doesn’t detect any device. With the Net.ether82595 it
detects the card but not obtain the MAC address. I don’t know if exists an update of this (mine is 30585 Kb)
With the 82551ER and the Net.ether82557 and the 701 patch it detects the card but don’t obtain the MAC.
I don´t know if I do something wrong or if these drivers are incorrect.
Can anyone help me? Thank you.
RE: Intel LAN drivers
Please try the attached driver.
From: Gerard Pou [mailto:community-noreply@qnx.com]
Sent: Friday, January 15, 2010 9:35 AM
To: qnx4-community
Subject: Intel LAN drivers
Dear all,
I have two motherboards with Intel LAN cards, models 82562GZ and 82551ER. I tried both but don't work under QNX.
With the 82562GZ I load the Net.ether82557 and the 701 patch. It doesn't detect any device. With the Net.ether82595 it
detects the card but not obtain the MAC address. I don't know if exists an update of this (mine is 30585 Kb)
With the 82551ER and the Net.ether82557 and the 701 patch it detects the card but don't obtain the MAC.
QNX4 Community Support
http://community.qnx.com/sf/go/post45294
Attachment: Text Net.ether82557 49.87 KB
Re: RE: Intel LAN drivers
Thank you very much.
The 82551ER appears to works fine with this driver. Some commands don´t obtain the MAC but it don´t appears to be a
big problem.
The 82562GZ don´t works with this driver. I have the Net.ether82595 that detects the card but don´t connect. My
release is from 1999. Do you know about an update?
Thank you.
Best regards.
RE: RE: Intel LAN drivers
The Net.ether82557 driver should work with both adapters. Please post the output from 'show_pci -v' and also start the
driver with -vvv and see what it says about the 82562 chip.
Sent: Monday, January 18, 2010 5:46 AM
To: qnx4-community
Subject: Re: RE: Intel LAN drivers
big problem.
Thank you.
Best regards.
http://community.qnx.com/sf/go/post45373
Re: RE: RE: Intel LAN drivers
If I use –vvv nothing new happens, it says “DriverInit: Unable to locate adapter.”
I attach the exit of the “show_pci –v” command.
Thanks.
Attachment: Text show_pci.dat 30.48 KB
RE: RE: RE: Intel LAN drivers
Sorry about that! The device ID wasn't in the driver. Please try the
attached driver.
Sent: Monday, January 18, 2010 10:45 AM
To: qnx4-community
Subject: Re: RE: RE: Intel LAN drivers
If I use -vvv nothing new happens, it says "DriverInit: Unable to locate
adapter."
I attach the exit of the "show_pci -v" command.
Thanks.
http://community.qnx.com/sf/go/post45395
Re: RE: RE: RE: Intel LAN drivers
This works fine! Thank you very much.
