10/14/2009 12:59 PM
post39927
Trying to boot from USB so I can get Hugh Brown some pciinfo data.
The USB boots, starts the QNX loader on partitiion 4 but it cant find the operating system
Not sure what I am missing
Did the following
Fsys.umass -v fsys -l -n Direct-Access=usb0
fdisk /dev/usb0
This works fine, set partitiion 4 to QNX, put on the loaded, made the partition bootable
mount -p /dev/usb0 /dev/usb0t77 /usb
dinit -h -f /boot/images/usb /dev/usb0t77
for the .boot file I have
sys/boot
$ boot -v
sys/Proc32
$ Proc32 -p 1024 -l 1 -D
sys/Slib32
$ Slib32
sys/Slib16
$ Slib16
/bin/io-usb
$io-usb
/bin/Fsys
$ Fsys -a -l 0 -c 100 -r 16384
/bin/Fsys.umass
$ Fsys.umass -v fsys -l -n Direct-Access=usb0
/bin/mount
$ mount -p /dev/usb0 /dev/usb0t77 /
/bin/sinit
$ sinit TERM=qnx
Any help would be appreciated
10/14/2009 1:43 PM
post39933
Do you have a /etc/config/sysinit file? sinit looks for this file.
From: dave allamby [mailto:community-noreply@qnx.com]
Sent: Wednesday, October 14, 2009 12:59 PM
To: qnx4-community
Subject: Booting from USB
Did the following
fdisk /dev/usb0
partition bootable
sys/boot
$ boot -v
sys/Proc32
sys/Slib32
$ Slib32
sys/Slib16
$ Slib16
/bin/io-usb
$io-usb
/bin/Fsys
/bin/Fsys.umass
/bin/mount
/bin/sinit
$ sinit TERM=qnx
QNX4 Community Support
http://community.qnx.com/sf/go/post39927
10/14/2009 2:01 PM
post39938
Hugh,
Not yet...I will add it...but think I have an problem with .boot
When I start the USB i get
Qnx Loader
Boot Partition 4
Missing Operating System
I did get a warning that the OS size exceeds 630784 bytes and may not
load correctly
so I took out the slib16 to get the size down and I still get the
missing os warning
> To: qnx4-community
> Did the following
> fdisk /dev/usb0
> partition bootable
> sys/boot
> $ boot -v
> sys/Proc32
> sys/Slib32
> $ Slib32
> sys/Slib16
> $ Slib16
> /bin/io-usb
> $io-usb
> /bin/Fsys
> /bin/Fsys.umass
> /bin/mount
> /bin/sinit
> $ sinit TERM=qnx
> http://community.qnx.com/sf/go/post39933
10/14/2009 2:12 PM
post39940
Have you tried dinit'ing it without the '-h', so that it thinks that it
is a floppy? Some BIOSes think that it is a floppy.
Sent: Wednesday, October 14, 2009 2:01 PM
To: qnx4-community
Subject: Re: Booting from USB
Hugh,
Qnx Loader
Boot Partition 4
load correctly
missing os warning
> To: qnx4-community
> Did the following
> fdisk /dev/usb0
> partition bootable
> sys/boot
> $ boot -v
> sys/Proc32
> sys/Slib32
> $ Slib32
> sys/Slib16
> $ Slib16
> /bin/io-usb
> $io-usb
> /bin/Fsys
> /bin/Fsys.umass
> /bin/mount
> /bin/sinit
> $ sinit TERM=qnx
http://community.qnx.com/sf/go/post39938
10/14/2009 2:14 PM
post39941
Hugh,
Yes, it does not work....it knows there is a partition table on the device
I will grab one of my other USB drives and see if I can format without a
table
Dave
> To: qnx4-community
> Hugh,
> Qnx Loader
> Boot Partition 4
> load correctly
> missing os warning
>> -----Original Message-----
>> To: qnx4-community
>> Did the following
>> fdisk /dev/usb0
>> partition bootable
>> sys/boot
>> $ boot -v
>> sys/Proc32
>> sys/Slib32
>> $ Slib32
>> sys/Slib16
>> $ Slib16
>> /bin/io-usb
>> $io-usb
>> /bin/Fsys
>> /bin/Fsys.umass
>> /bin/mount
>> /bin/sinit
>> $ sinit TERM=qnx
> http://community.qnx.com/sf/go/post39940
10/16/2009 1:20 AM
post40089
Hugh
In attempting to get the OS running on the PowerEdge R200, I was doing
some experimenting on the Dell PowerEdge 860 and found that io-usb locks
up the machine.
Can you take a look at the show_pci output and see if there is something
I can do to correct this.
Dave
> To: qnx4-community
> Hugh,
> Qnx Loader
> Boot Partition 4
> load correctly
> missing os warning
>> To: qnx4-community
>> Did the following
>> fdisk /dev/usb0
>> partition bootable
>> sys/boot
>> $ boot -v
>> sys/Proc32
>> sys/Slib32
>> $ Slib32
>> sys/Slib16
>> $ Slib16
>> /bin/io-usb
>> $io-usb
>> /bin/Fsys
>> /bin/Fsys.umass
>> /bin/mount
>> /bin/sinit
>> $ sinit TERM=qnx
10/16/2009 8:01 AM
post40101
No, I can't see anything strange about the show_pci output. I will have
to pass this on to our USB expert to have a look at it.
Hugh.
Sent: Friday, October 16, 2009 1:20 AM
To: qnx4-community
Hugh
up the machine.
Dave
it
> To: qnx4-community
> Hugh,
> Qnx Loader
> Boot Partition 4
> load correctly
> missing os warning
>> To: qnx4-community
find
>> Did the following
>> fdisk /dev/usb0
>> partition bootable
>> sys/boot
>> $ boot -v
>> sys/Proc32
>> sys/Slib32
>> $ Slib32
>> sys/Slib16
>> $ Slib16
>> /bin/io-usb
>> $io-usb
>> /bin/Fsys
>> /bin/Fsys.umass
>> /bin/mount
>> /bin/sinit
>> $ sinit TERM=qnx
http://community.qnx.com/sf/go/post40089
10/20/2009 9:50 AM
post40327
Hi Dave,
Have you tried to force different CHS geometry for USB Stick ?
Try to pass another "CHS configuration" to Fsys.umass and then create QNX4 partition once again.
Good luck,
Jacek
10/20/2009 10:49 AM
post40336
Jacek,
Thanks, that allowed me to boot off USB. Running into limitations with
regards to the boot image size, I am getting the OS size exceeds
630784 but seems to boot ok
Dave
Hugh
I am using this usb boot on the PowerEdge R200. I have included io-usb
in the boot image and it crashes at D1:0000FE6E
Dave
Jacek Rudnicki wrote:
> Hi Dave,
> Good luck,
> Jacek
> http://community.qnx.com/sf/go/post40327
10/20/2009 11:16 AM
post40338
Dave,
I really don't know what's going on. I suggest that you speak to your
sales rep to try and find a resolution to this problem.
Thanks, Hugh.
Sent: Tuesday, October 20, 2009 10:50 AM
To: qnx4-community
Jacek,
Dave
Hugh
Dave
> Hi Dave,
> Good luck,
> Jacek
http://community.qnx.com/sf/go/post40336
10/21/2009 7:36 AM
post40401
Hi Dave,
> I am getting the OS size exceeds 630784 but seems to boot ok
In my opinion the OS image ~630kB is too big.
Have you tried with any other but smaller image (just to see if it will boot fine) ?
As far as I know OS image with size less than 620kB is all what can do.
Jacek
10/21/2009 8:01 AM
post40404
The theory says close to 640k but the thing is the BIOS takes somes spaces of it own out of that 640k.I have seen a PC
equipped with a network card that had a ROM BIOS that couldn`t handle image bigger then 520k. Your mileage may vary.
> From: Jacek Rudnicki [mailto:community-noreply@qnx.com]
> Sent: October 21, 2009 7:37 AM
> To: qnx4-community
> Hi Dave,
> boot fine) ?
> Regards,
> Jacek
> http://community.qnx.com/sf/go/post40401
10/21/2009 10:44 AM
post40431
Jacek,
I downloaded and tried to install the new 2009 experimental product CD
and I get the same error.
I made a boot file that was only 320k that just runs show_pci and it
crashes at the same location as Fsys.atapi FE6E
Talking with support team now, hopefully can get this sorted
out...customer getting anxious
Dave
> Hi Dave,
> Regards,
> Jacek
10/22/2009 4:14 AM
post40479
Dave,
Try to boot from USB Stick on the other machine.
Can you send this or any other OS image which fails on your hardware ?
My image ~618kB boots fine from USB here.
Jacek
>Jacek,
>Dave
