Forum Topic - QNX Thread Destruction: (3 Items)
Questions:
1. What exactly happens when a thread is destroyed?
2. Which QNX document supports the answer to question 1? I'm interested in seeing what else it has.
Contex:
An application process is executed which creates a helper thread. The helper thread executes its routine and then just
returns from that routine. It appears that at least one object utilized by the thread has its destructor invoked. The
object belongs to a pointer member of a struct. That struct is passed to pthread_create().
I was surprised to learn that the object's destructor was invoked. So I'd like to better understand exactly what goes on
 during thread destruction.
Thanks for your insights!
RE: QNX Thread Destruction
Are you using QNX 4 or Neutrino? QNX 4 doesn't support real threads, and
I don't think it implemented pthread_create().
If you really are using Neutrino, you might want to post your questions
in a different forum. However, I don't think there are any documents
that describe exactly what happens when a thread is destroyed. If you
use the System Analysis Toolkit and the IDE's System Profiler, you can
see some cleanup events flying around.
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
> From: Daniel Orozco [mailto:community-noreply@qnx.com]
> Sent: Saturday, October 10, 2009 2:35 PM
> To: qnx4-community
> Subject: QNX Thread Destruction
> Questions:
> Contex:
> on during thread destruction.
> QNX4 Community Support
> http://community.qnx.com/sf/go/post39712
Hi Steve,
I am using Neutrino. I'll post the question in a different forum. I'll also use the Sys Analysis Toolkit and Sys
Profiler as you suggested.
Thanks for pointing me in the right direction!
Dan Orozco
Software Engineer
SRC - Systems Technology Center
dorozco@syrres.com
From: Steve Reid [mailto:community-noreply@qnx.com]
Sent: Tuesday, October 13, 2009 1:35 PM
To: qnx4-community
Subject: RE: QNX Thread Destruction
Technical Editor
> To: qnx4-community
> Questions:
> Contex:
http://community.qnx.com/sf/go/post39800
