promiscuous mode in QNX 6.41 on x86 platform
10/06/2009 3:21 AM
post39415
I have a problem with promiscuous mode in QNX 6.41 on x86 platform.
When I use devn-rtl8169.so (from QNX 6.40 instalation) everything is OK - promiscuous mode works.
In file /etc/system/enum/devices/net is
mount(-Tio-pkt "-opci=$(index),vid=0x$(ven),did=0x$(dev)" /lib/dll/devn-rtl8169.so, "/dev/io-net/en$(netnum)")
When I use devnp-rtl8169.so promiscuous mode doesn't work.
mount(-Tio-pkt "-opci=$(index),vid=0x$(ven),did=0x$(dev)" /lib/dll/devnp-rtl8169.so, "/dev/io-net/en$(netnum)")
As an interface I use libpcap.a library. All src code is below.
It seems that new drivers devnp* make device rt0 and promiscuous mode doesn't work.
Is this only termporary phase (there are devn* and devnp* drivers in instalation) or promiscuous mode won't be suported
any more?
Or should I set promiscuous mode in other way? (pcap_open_live - the third parameter is set to 1)
Pavel Šimek
//all src code
#include <sys/neutrino.h> // #define _NTO_VERSION
#include <pcap.h>
int main()
pcap_if_t *alldevs;
pcap_if_t *d;
int inum;
int i=0;
pcap_t *adhandle;
int res;
char errbuf[PCAP_ERRBUF_SIZE];
struct tm *ltime;
char timestr[16];
struct pcap_pkthdr *header;
const u_char *pkt_data;
if(pcap_findalldevs(&alldevs, errbuf) == -1){
fprintf(stderr,"Error in pcap_findalldevs: %s\n", errbuf);
return -1;
/* Print the list */
for(d=alldevs; d; d=d->next)
printf("%d. %s", ++i, d->name);
if (d->description)
printf(" (%s)\n", d->description);
else
printf(" (No description available)\n");
if(i==0)
printf("\nNo interfaces found! Make sure WinPcap is installed.\n");
return -1;
printf("Enter the interface number (1-%d):",i);
scanf("%d", &inum);
if(inum < 1 || inum > i)
printf("\nInterface number out of range.\n");
/* Free the device list */
pcap_freealldevs(alldevs);
return -1;
/* Jump to the selected adapter */
for(d=alldevs, i=0; i< inum-1 ;d=d->next, i++);
/* Open the adapter */
if ((adhandle= pcap_open_live(d->name, 65536, 1 /* nonzero promiscuous*/, 100, errbuf )) == NULL)
fprintf(stderr,"\nUnable to open the adapter. %s is not supported by WinPcap\n", d->name);
return -1;
printf("\nlistening on %s...QNX:%d\n", d->name, _NTO_VERSION);
/* At this point, we don't need any more the device list. Free it */
/* Retrieve the packets */
while((res = pcap_next_ex( adhandle, &header, &pkt_data)) >= 0){
if(res == 0)
continue;
/* convert the timestamp to readable format */
ltime=localtime(&header->ts.tv_sec);
strftime( timestr, sizeof timestr, "%H:%M:%S", ltime);
printf("%s,%.6d len:%d\n", timestr, header->ts.tv_usec, header->len);
if(res == -1){
printf("Error reading the packets: %s\n", pcap_geterr(adhandle));
return -1;
pcap_close(adhandle);
return 0;
