Forum Topic - trying to delete QNX header files during make htinstall:
good afternoon:
i am trying to build QNX software and i keep getting these errors:
cp: cannot remove `/opt/qnx630/target/qnx6/usr/include/hw/dsiu.h': Permission denied
cp: cannot remove `/opt/qnx630/target/qnx6/usr/include/hw/s2681.h': Permission denied
cp: cannot remove `/opt/qnx630/target/qnx6/usr/include/hw/bcm1250.h': Permission denied
cp: cannot remove `/opt/qnx630/target/qnx6/usr/include/hw/zscc.h': Permission denied
cp: cannot remove `/opt/qnx630/target/qnx6/usr/include/hw/8250.h': Permission denied
cp: cannot remove `/opt/qnx630/target/qnx6/usr/include/hw/ucb1300.h': Permission denied
make[6]: [hinstall] Error 1 (ignored)
it happens only during the make htinstall stage. i found the same errors when building the QNX kernel (CoreOS) in trunk/
for trunk, as soon as you set QCONF_OVERRIDE, the error disappears. the error is so cryptic, its difficult to find the
cause.
whats the solution? is it because QCONF or QCONF_OVERRIDE is not defined?
thank you in advance.
have a nice day,
Aaron
  still using Netscape 7.4 after all these years
  http://browser.netscape.com/releases
  also using Firefox, Chrome, Opera, Konqueror, IE, Safari
Re: trying to delete QNX header files during make htinstall
On Wed, Sep 23, 2009 at 09:08:16AM -0400, Aaron P. D'Souza wrote:
> good afternoon:
trunk/.
 cause.
Probably.  You should set up a staging area so that
you're not trying to overwrite the shipped headers
which you don't have perms to do.
http://community.qnx.com/sf/wiki/do/viewPage/projects.core_os/wiki/BuildTheOSSource
good evening Sean, others:
do you need a Staging Area for normal QNX applications and for BSPs? do you need to set QCONF for applications and the
BSPs?
in our BSP tree, all directories do not have a pinf.mk or qconf.mk.
cheers!
Aaron
Hi Aaron,
Which QNX version do you have installed as your development host?  It appears to be 6.3.0 or perhaps 6.3.0SP2 + the 6.3.
2 patch?
I should warn you that you will have troubles completing the build of the utilities and libraries with a development
system this
old, due to dependencies on new compilers, newer qcc conf files, and changes to the crt*.o files in $QNX_TARGET/$CPU/lib
I'll make a note on the build page...
 BSPs?
> cheers!
> Aaron
> http://community.qnx.com/sf/go/post38680
cburgess@qnx.com
