Trackers
Trackers
Forum Topic - QNX 6.4.1 serial file transfer with QCP or Zmodem tools?: (3 Items)
I am working on a project that requires sending files over a serial link to/from a PC from/to a device running QNX
Neutrino 6.4.1.  The serial link is a requirement because it is passing through a Blutooth SPP bridge.
The zmodem protocol would be my preferred method but these tools appear to have been "depreciated" as of 6.4.0.
Instead there is a program called QCP which appears to work in a similar way.  The only problem is that I can't find any
 tools for non-Neutrino OSes that will let me actually send or receive files using QCP.  I am primarily using windows.
Does such a program exist or is QCP only usefull between devices running Neutrino.
Also, is there a good way to get the "depreciated" zmodem tools back and just use them.  That way my users could use
Hyper Terminal and wouldn't need a special (possibly nonexistent) QCP compatible program for the transfer.
I feel like I must be missing some information because no one else seems to be mentioning this oversight.  Or does no
one ever use serial for file transfers anymore.
As a side note, qtalk still lets you try to use zmodem tools but fails because they are not available.
      Scott
Re: QNX 6.4.1 serial file transfer with QCP or Zmodem tools?
You probably can get Kermit for this. I haven't tried it for Neutrino, but it worked fine under 4.25. Unfortunately,
it's not free for Windows, but I don't think it's very expensive.
On Tue, 25 Aug 2009, Scott Rainwater wrote:
>Date: Tue, 25 Aug 2009 17:58:38 -0400 (EDT)
>From: Scott Rainwater <community-noreply@qnx.com>
>Reply-To: post36675@community.qnx.com
>To: general-community <post36675@community.qnx.com>
>Subject: QNX 6.4.1 serial file transfer with QCP or Zmodem tools?
> to/from a PC from/to a device running QNX Neutrino 6.4.1.  The serial link is
> The only problem is that I can't find any tools for non-Neutrino OSes that
> windows.  Does such a program exist or is QCP only usefull between devices
> running Neutrino.
> use them.  That way my users could use Hyper Terminal and wouldn't need a
The source code for this has been moved to the bazaar site on the foundry:
http://community.qnx.com/integration/viewvc/viewvc.cgi/trunk/l/lrzsz/?root=bazaar&system=exsy1001
You should be able to access/build it from there for your target.
Hope this helps,
Peter
> be mentioning this oversight.  Or does no one ever use serial for file
> transfers anymore.
> Thanks,
>      Scott
> http://community.qnx.com/sf/go/post36675
