Forum Topic - Reg. pthreads compilation. :
Hi All,
I am using QNX 6.4.0 version and application using pthreads, when I compile my application it give me following errors.
qnx/osixqnx.c:134: error: 'pthread_attr_t' has no member named 'flags'
qnx/osixqnx.c:135: error: 'pthread_attr_t' has no member named 'flags'
qnx/osixqnx.c:152: warning: assignment from incompatible pointer type
pthread_attr_t      Attr;
Attr.flags |= PTHREAD_MULTISIG_DISALLOW;
Attr.flags |= PTHREAD_CREATE_DETACHED;
If I see pthread_attr_t  structure in target_nto.h file flags are there in the structure.
Can anybody help me to solve this issue.
vinod.
Re: Reg. pthreads compilation.
Hi Vinod,
the member name is '__flags' (with two leading underscores).
Your code should read
  Attr.__flags |= PTHREAD_MULTISIG_DISALLOW;
  Attr.__flags |= PTHREAD_CREATE_DETACHED;
Kind regards,
- Thomas
However you should be use pthread_attr_setdetachstate() for PTHREAD_CREATE_DETACHED
Thomas Haupt wrote:
> Hi Vinod,
> Kind regards,
> - Thomas
> http://community.qnx.com/sf/go/post33635
cburgess@qnx.com
Thanks Thamus,
I have one more problem.
I am using following structure, it is defined in net/if.h.
struct ifreq        ifr;
ifr.ifr_flags = ifr.ifr_flags | IFF_PROMISC;
When I compile my application following errors displayed,
 error: storage size of 'ifr' isn't known
 error: invalid application of 'sizeof' to incomplete type 'struct ifreq'
error: 'IFF_PROMISC' undeclared (first use in this function)
Thanks again,
vinod.
