Forum Topic - Phindows under Vista?: (2 Items)
I have a version of Phindows on my XP machine that seems to be dated about 2004, from a 6.3 IDE that I installed
probably around 2005. I would like to install Phindows on a Vista Business Edition laptop, after purchasing the
appropriate license from QNX, of course.
Are there any known problems using Phindows under Vista?
Is there a more recent version of Phindows that I should get, and, if so, how do I get it?
Is there any way to log or capture screen events while monitoring a remote Photon session?
Kevin
RE: Phindows under Vista?
The older version of Phindows that you have should work fine under
Vista.
There are new features in later versions of Phindows that you may wish
to take advantage of though. You can ask your QNX salesperson about the
"Phindows Standalone product", which is just Phindows by itself.
Unfortunately there is currently no facility in Phindows to report on
screen events. What kind of events are you interested in? Phindows does
receive the full draw stream, so in theory it can check for events in
some detail.
Max
mfeil@qnx.com
P.S. The only known issues on Vista started with Phindows version 3.29
(a.k.a. 3.0.29 which is later than yours) and the double buffering
feature. There were performance problems noted by some users because
double buffering uses Direct3D, and is redundant if the Vista Aero
compositing is active. The workaround is to disable double buffering in
the Phindows menu (or using a command line option). Phindows does this
check automatically as of version 3.0.37, which means the issue is
resolved in Momentics 6.4.1 and the current Phindows Standalone Product
that coincides with 6.4.1.
From: Kevin Miller [mailto:community-noreply@qnx.com]
Sent: Thursday, June 18, 2009 6:37 PM
To: general-community
Subject: Phindows under Vista?
about 2004, from a 6.3 IDE that I installed probably around 2005. I
purchasing the appropriate license from QNX, of course.
Kevin
General
http://community.qnx.com/sf/go/post32080
