Forum Topic - Disable Broadcast on a single QNX interface:
I'm using Neutrino 6.4.0 on a number of virtual machines, using VMware.
I have one VM acting as a gateway with a Bridged interface to my user LAN, and another interface configured as host only
. I then have a number of other VMs with just a single a host only interface configured. The idea is that each of these
machines will communicate over the host only virtual LAN, and I use the bridged interface for access, copying files etc.
Some of the traffic sent between the hosts is broadcast ethernet, but I want to ensure these broadcasts on the gateway
machine dont leak onto the user LAN. Is there a command (using ifconfig or some equivalent) whereby I can disable
broadcast on my bridged interface?
Dan
Re: Disable Broadcast on a single QNX interface
I'm assuming the answer to this query is no or have all the QNX experts gone on holiday? :)
Is it possible to disable Ethernet Broadcast on a single bridged interface within the QNX stack?
Not currently with ifconfig.  From <net/if.h>
/* flags set internally only: */
#define IFF_CANTCHANGE \
        (IFF_BROADCAST|IFF_POINTOPOINT|IFF_RUNNING|IFF_OACTIVE|\
            IFF_SIMPLEX|IFF_MULTICAST|IFF_ALLMULTI|IFF_PROMISC|IFF_SHIM)
You might be able to set up some pf rule...
