editor support for QNX 6.4
05/05/2009 3:12 PM
post28731
Hi.
Not sure if this is this place to ask this question.
I’m trying out QNX 6.4, self hosted, photon.
I need to get a syntax highlight editor(s) for c.
What are my options? Where can I get them from?
TIA
Augie
RE: editor support for QNX 6.4
05/05/2009 3:41 PM
post28734
> From: Augie Henriques [mailto:community-noreply@qnx.com]
> Sent: May-05-09 3:12 PM
> To: general-community
> Subject: editor support for QNX 6.4
> Hi.
There is vim/gvim I believe or workspace or like QNX wants you to do, switch to Linux or Windows and use Eclipse. I
mean you paid for Momentic, right. Oh no sorry you paid for it but you can't use it on self hosted, my bad...
> TIA
> Augie
> http://community.qnx.com/sf/go/post28731
Re: RE: editor support for QNX 6.4
05/05/2009 4:00 PM
post28740
does gvim run on QNX 6.4? Where do I get it?
RE: RE: editor support for QNX 6.4
05/05/2009 4:05 PM
post28744
> Sent: May-05-09 4:01 PM
> Subject: Re: RE: editor support for QNX 6.4
Hum on 6.4 don't know. I installed it on 6.3.2 via the third party CD, don't know how you would install it in QNX6.4.0.
Maybe it's in the pkgsrc?
Just try taking the gvim I have on 6.3.2 ( version 6.1) and copy the binary on 6.4.0 and it works! But if memory serves
me right it has problem with color?
> http://community.qnx.com/sf/go/post28740
Re: RE: RE: editor support for QNX 6.4
05/07/2009 1:12 PM
post28962
would I be able to get the gvim to try? do you have .vimrc file to go with this? TIA
05/07/2009 7:37 PM
post28987
I got gvim going on the HEAD_641 branch in a new vim-photon
package. Here's the diff that you can try backporting to
the HEAD_640 branch if you're feeling adventurous.
| Attachment: |
diff
7.2 KB
05/05/2009 4:08 PM
post28745
It should run without issue on 6.4, if you have gtk installed. I don't have
a neutrino install up at the moment so I can't answer with absolute
certainty. GVim is just a GUI for Vim, which you can obtain from
www.vim.org (I used version 7.1); to compile gvim, you'll have to look at
the options under ./configure --help (there are a plethora of UI options,
one of them is for a GTK user interface, which is GVim)
-Aaron
On Tue, 5 May 2009 16:00:43 -0400 (EDT), Augie Henriques
05/07/2009 9:21 AM
post28892
Is GTK installed on QNX 6.4? How do I check? How do I install it?
05/07/2009 9:43 AM
post28901
It's not there unless you installed it. If I were
to install it I'd use pkgsrc:
http://community.qnx.com/sf/projects/pkgsrc
Installing binary packages is described here:
http://community.qnx.com/sf/wiki/do/viewPage/projects.pkgsrc/wiki/BinaryPackages
The gtk+ binary package is here:
ftp://ftp.netbsd.org/pub/pkgsrc/packages/QNX/i386/6.4.0_head_20081005/All/gtk+-1.2.10nb9.tgz
To check if it's installed I'd use the 'pkg_info' utility.
05/07/2009 10:46 AM
post28930
I modified step 1 to modify the PATH and CS_LIBPATH.
Not sure how to go from here? How do I install this?
05/07/2009 10:59 AM
post28933
If you're talking about pkgsrc I wouldn't modify the
steps; just follow them as outlined here:
If you have a specific question, fire away...
05/07/2009 11:22 AM
post28938
I was able to download the bootstrap.tar.gz.
I untar under (/). What is the next step? Do I need to install something? I'm I ready to install the GTK?
05/07/2009 11:27 AM
post28940
As mentioned in the aforementioned link:
# export PATH=$PATH:/usr/pkg/bin:/usr/pkg/sbin
# setconf CS_LIBPATH $(getconf CS_LIBPATH):/usr/pkg/lib
# mkdir /var/tmp
# export PKG_PATH=ftp://ftp.netbsd.org/pub/pkgsrc/packages/QNX/i386/6.4.0_head_20081005/All
# pkg_add -v gtk+
05/07/2009 11:50 AM
post28947
ok. Thanks. That was complicated. A labor of love. :-)
Where do I find gvim to install? do I need to reboot after this?
05/07/2009 11:52 AM
post28948
gvim I dunno. Plain vim works. But enjoy your gtk+ :)
05/07/2009 11:53 AM
post28949
Try starting vim with -g ( not sure of the option), if it was build with graphical support in it should work.
> From: Sean Boudreau [mailto:community-noreply@qnx.com]
> Sent: May-07-09 11:53 AM
> -seanb
> http://community.qnx.com/sf/go/post28948
05/07/2009 12:13 PM
post28956
Looks like this is supposed to be in the vim-gtk package but the
FEAT_GUI_PHOTON support has rotted.
05/08/2009 9:04 AM
post29012
I got the vim72 sources. While compiling I get an error looking for os_qnx.h file. How did you get pas this error? TIA
Re: editor support for QNX 6.4
05/05/2009 3:45 PM
post28735
You can't go wrong with vim (provided you have syntax highlighting enabled
in your vimrc),
or *shudders* emacs.
I know that vim will compile under neutrino, IIRC there was some
configuration hacking, but it shouldn't be difficult.
I do believe there are also editors under the pkgsrc project that will suit
your needs as well.
Hope this helps, feel free to write back if you need more information.
Cheers,
-Aaron
On Tue, 5 May 2009 15:12:16 -0400 (EDT), Augie Henriques
> Hi.
> TIA
> Augie
05/05/2009 3:49 PM
post28736
> From: Aaron Cripps [mailto:community-noreply@qnx.com]
> Sent: May-05-09 3:46 PM
> Subject: Re: editor support for QNX 6.4
> enabled
> in your vimrc),
> suit
> your needs as well.
Come on Aaron; vim, what??? A non GUI editor, that's almost as bad and old-fashion as self-hosted itself. You can't
seriously recommend one of the most efficient editor over a nice looking editor with graphical menus and stuff???
> Cheers,
> -Aaron
> > Hi.
> > TIA
> > Augie
> > General
> http://community.qnx.com/sf/go/post28735
05/05/2009 4:04 PM
post28742
You know Mario, I'm not sure if you're trying to be sarcastic, or not.
Vim is nice, it's all i ever used when I was at QNX; There are the gui
versions though, like GVim, or Vim/Cream.
Cheers,
-Aaron
On Tue, 5 May 2009 15:49:22 -0400 (EDT), Mario Charest
>> -----Original Message-----
>> enabled
>> in your vimrc),
>> suit
>> your needs as well.
> old-fashion as self-hosted itself. You can't seriously recommend one of
> and stuff???
>> Cheers,
>> -Aaron
>> > Hi.
>> > TIA
>> > Augie
>> > _______________________________________________
>> > General
>> General
> http://community.qnx.com/sf/go/post28736
05/05/2009 4:05 PM
post28743
> Sent: May-05-09 4:05 PM
> Subject: RE: editor support for QNX 6.4
I'll let you dwell on that ;)
> Cheers,
> -Aaron
> >> enabled
> >> in your vimrc),
> will
> >> suit
> >> your needs as well.
> and
> of
> menus
> > and stuff???
> information.
> >> Cheers,
> >> -Aaron
> >> > Hi.
> >> > TIA
> >> > Augie
> >> > General
> >> General
> > General
> http://community.qnx.com/sf/go/post28742
05/07/2009 1:11 PM
post28961
vim does't show color in c file. I have syntax = on in .vimrc file. what is missing?
05/07/2009 3:52 PM
post28976
Here's my .vimrc
05/08/2009 9:16 AM
post29013
05/06/2009 9:10 AM
post28785
On Tue, May 05, 2009 at 03:12:17PM -0400, Augie Henriques wrote:
> Hi.
> I???m trying out QNX 6.4, self hosted, photon.
> TIA
> Augie
I use vim in a pterm. You might want to check out
the pkgsrc project:
05/07/2009 1:27 PM
post28964
I did. The color doesn't work. I also tried vim -g, it says it can't be used with a GUI, not compiled that way.
What now?
