Forum Topic - TODO Task bar under Momentics 6.3.x:
A quick cherry for someone to pick.
How do I enable the TODO comments to show up?
Thanks.
Re: TODO Task bar under Momentics 6.3.x
Open Tasks View? Window->Show View->Tasks
Lior Keinan wrote:
> Hello,
> Thanks.
> http://community.qnx.com/sf/go/post22554
Thank you Elena.
I did add the task view but even rebuilding the index and/or restarting the IDE doesn't show the TODOs I have.
I placed a couple across *.cc and *.c files in a x86 project derived from teh "hello world" example
> Thank you Elena.
> Thanks
sorry I actually upgraded to 4.0.1
Associations:
post22579:
              Re: TODO Task bar under Momentics 6.3.x -  - Lior Keinan(disabled)
> > Thank you Elena.
> teh
> > Thanks
> sorry I actually upgraded to 4.0.1 Build id: I20070321
Associations:
post22578:
Is it qnx project or managed project?
You can check Window->Preferences->C/C++->Task Tags - but I am pretty sure TODO keyword is default there
Can you attach your project?
Lior Keinan wrote:
>>> Thank you Elena.
>> teh
>>> Thanks
> http://community.qnx.com/sf/go/post22579
It is an empy QNX C Project, See attached.
I intalled the latest SDP 6.4 on top of a SDP 6.3.x
Also I'm used to working with Ganymede Managed Projects so there might be some misconceptions, how high up as far as
Eclipse tools should I expect the QNX IDE to go?
Thanks again.
Attachment: Compressed file Hello.zip 9.15 KB
If you used to use managed project you still can use them. IDE 4.5 which comes with SDP 6.4 running on top of CDT Europa
If you want Ganymede you can use experimental IDE 4.6, there are download and installation instructions of the  wiki
page.
Managed project with qnx tool chain provide almost identical functionality as qnx project (but without makefiles).
I cannot make TODO work for simple qnx project, I will open a PR about it, thanks.
> Thanks again.
> http://community.qnx.com/sf/go/post22677
