Forum Topic - Virtual COM Port, Making USB look like COM:
Hello.
This is the task i have:
The program connects to a COM-Port to send/receive data. The that should be used is connected to the USB. I need a
driver/program that creates a virtual port makes the USB look like a COM-Port to the program and that converts the data
in both directions.
I dont want to use additional hardware. Is the devc-serusb the right thing??
Thank you for your help.
Re: Virtual COM Port, Making USB look like COM
devc-serusb is expecting a prolific chip (PL-2303) complete with registers and a hw queue sitting between the usb driver
 and the serial connection.  I doubt you would find much that directly applies to your problem.
I would think you would have to program the usb chip directly - skipping any "normal" usb driver.  Setting the transmit/
receive clocks to match the baud clock would be the first issue.
